Author Topic: last call on Audi TT trans to rabbit axles and VR6 shift box  (Read 3794 times)
July 21, 2007, 04:44:06 pm
Justin
  • 455
I have a set of axles with Brand new inner cv joints for an Audi TT transmission and they are welded to a set of outer VW rabbit axles for anyone who wants to do the swap, they might need a little adjusting depending on transmission and positioning.  but they have never been run
I am moving out saturday from my apartment in Tucson to go back to Michigan and I have no use for them since I ended up using a 02j trans and the stock 100mm inners for a rabbit bolted right up.
I also have a VR6 style cable shift box if anyone is interested as well and its the same deal as the axles.
make a reasonable offer (CHEAP) and they are yours. I have pictures if you want and the outer cvs are not included as they are now on my TDI-M rabbit
Thanks
Justin
www.archeryprostaffmi.com
