Author Topic: How much PSI will a mk1 fuel filter handle?  (Read 3844 times)
July 19, 2007, 02:24:50 pm
« on: July 19, 2007, 02:24:50 pm »
The title pretty much says it all. I think I need something that will handle over 100psi. Also what temp would it be good up to?
Reply #1July 19, 2007, 02:47:57 pm
bevboyy
  • 200
« Reply #1 on: July 19, 2007, 02:47:57 pm »
Tyler, the design of the stock filter would not hold anything over 40 psi.
You're going to have to use one off a car that has multi port FI. GM Vortex comes to mind as their fuel pressure is close to 100 psi.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #2July 19, 2007, 02:52:04 pm
« Reply #2 on: July 19, 2007, 02:52:04 pm »
Thanks, you probably just saved the life of my engine :lol:
Actually what is the max oil pressure ever created with a not so healthy engine?
Aren't the mk1 CIS engines pushing close to 100PSI as well?
Reply #3July 19, 2007, 03:01:35 pm
bevboyy
  • 200
« Reply #3 on: July 19, 2007, 03:01:35 pm »
Oil pressure should be around 60 psi if memory serves me right.
The CIS pressurizes the fuel at the fuel distributor. The pump is I think 90gal/min - this again is by memory..
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #4July 19, 2007, 08:17:02 pm
hillfolk'r
  • 1532
« Reply #4 on: July 19, 2007, 08:17:02 pm »
ive had my  fuel  pump regulator act up,and send 50-60 psi to the pump before without blowing out......
im using a cis pump for a lift pump with a cheezy  home depot regulator  to  bypass the extra pressure
i normally keep it at 42 psi(idling),cause under a load itll drop to mid 30s
any less,and it drops severely under a load
cool thing is i can open the pass. door and reach unde r  the car and adjust the regulator+watch my psi guage in my console
been like that for over a year
Throttle cables ftw
