Author Topic: BFI exhaust manifold  (Read 3293 times)
July 18, 2007, 04:07:14 am
knowtwodrugs
  • 46
« on: July 18, 2007, 04:07:14 am »
Has anyone run one of these on a 1.6 TD?
http://store.blackforestindustries.com/duouexma.html
- Ayrer Performance & Machine -
Performance Valve Jobs, Rod Resizing, Crank Grinding & Polishing, Cam Bearings, Block Squaring, Block Boring, Head Milling, Etc...
 "Complete Engine Design For The Type Of Racing That You Do!"
609-835-0779
Over 25 Years Experience
Reply #1July 18, 2007, 02:06:05 pm
foxracer1
  • 991
« Reply #1 on: July 18, 2007, 02:06:05 pm »
I have one on my N/A. Its from a corrado gasser. i think i saw someone had used one of these turned upside down with a holset. Maybe that was hillfolk'r
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2July 18, 2007, 02:21:48 pm
« Reply #2 on: July 18, 2007, 02:21:48 pm »
Quote from: "foxracer1"
yeah it was that crazy fellow, i've also seen it done on a mk3 2.0
Reply #3July 19, 2007, 07:53:32 am
subsonic
  • 1836
« Reply #3 on: July 19, 2007, 07:53:32 am »
So is that manifold sort of like a dual pulse setup? Two cyl into one x 2, and then into turbo?  Does this offer better exhaust flow?  Does using this effect how the turbo will be placed, lines etc?
Reply #4July 19, 2007, 08:06:24 am
« Reply #4 on: July 19, 2007, 08:06:24 am »
That is NOT a turbo manifold.  It is an OEM dual-outlet manifold for gassers which is considered a cost-effective upgrade if you have the toilet bowl manifold.  I would think it would be hard to adapt this to a turbo application.
Reply #5July 19, 2007, 08:34:19 am
« Reply #5 on: July 19, 2007, 08:34:19 am »
just because it isn't doesn't mean it can'tbe :wink:
You'd be better getting a used one for like $40 or whatever they cost for mk2s, or even get one from a mk1 and make it work
Reply #6July 19, 2007, 06:02:05 pm
knowtwodrugs
  • 46
« Reply #6 on: July 19, 2007, 06:02:05 pm »
Hey thanks for the info guys.  I had no idea this was a stock application on some cars.  I'm just planning my long term goals for the 1.6 TD I just got and I thought I'd get all the info I could.  Passenger Performance no longer makes downpipes and manifolds am I correct?  Or does passenger diesel do any of that?
609-835-0779
Reply #7July 19, 2007, 07:03:34 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #7 on: July 19, 2007, 07:03:34 pm »
Quote from: "knowtwodrugs"
They are one and the same. I believe Dave is still making the manifolds and he has stopped making 2.5 downpipes but has started making 3" downpipes. Look for his post in the Vendors section. If you want to talk to him you would probably be better off calling him.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #8July 19, 2007, 07:48:33 pm
hillfolk'r
  • 1532
« Reply #8 on: July 19, 2007, 07:48:33 pm »
yea it was me....
i got a 1 inch thick block of steel  and milled it out on a milling machine to mate up to a t3 flange from the 6 bolt setup
i just milled the studs off+tapped out 4 new holes
then i "ported " the manifold outlets to  "sorta" meet in the middle ,,the metal between the outlets was removed and tapered to a point+slightly lower than the manifold surface
then the block sorta goes from an oval shape on the manifold on the one side,and tapers to the t3 flange
sorry i got no pics of the manifold "in progress"
if ya flip it over,just use the gaskets flipped over and scribe where you need to remove the material,so you can clear the intake
please  excuse the pic size,,i screwed up on the d/l
and yes 3 inch dp's DO fit mk1 chassis's
Throttle cables ftw
Reply #9July 19, 2007, 08:21:05 pm
foxracer1
  • 991
« Reply #9 on: July 19, 2007, 08:21:05 pm »
There's those pics i thought i saw.
91 S10 305 TPI T56
