Author Topic: cold start problem  (Read 3616 times)
July 17, 2007, 09:47:08 am
rov716y
  • 96
cold start problem
« on: July 17, 2007, 09:47:08 am »
tried staring my golf 3 mornings on the trot now and every morning warm plugs up relay clicks. so i turn her over and over and over and battery dies so i pull up the astra connect jump leads warm up glow plugs again, and she striked up first turn off the key.
my immediate thought was my battery not good enough or even over night diesel draining out off pipes but not 100% sure any help appreciated
Reply #1July 17, 2007, 11:08:51 am
bert
  • 423
cold start problem
« Reply #1 on: July 17, 2007, 11:08:51 am »
Eyl53v is playing up eh? try sitting in the car with the interior light on,turn ignition on,see if light goes dim,if it does the glow plugs are drawing power,also there is a fuse inline for the glow plugs
Bert
Reply #2July 17, 2007, 12:30:19 pm
rov716y
  • 96
cold start problem
« Reply #2 on: July 17, 2007, 12:30:19 pm »
yes she is!
the interior light isn't wired up lol
but i think i may have worked this one out
just now she killed the battery so hooked up my mums astra and she took a few tries to start i'm thinking its the glow plugs them selves. the in line fuse is fine (dangling in engine bay) and relay is new, but i think it may be the glow plugs them selves.  i'm gunna buy some new ones and see how she goes
Reply #3July 17, 2007, 12:34:13 pm
rov716y
  • 96
cold start problem
« Reply #3 on: July 17, 2007, 12:34:13 pm »
while i got you attention bert just a couple off q's
 should the be white smoke blowing out off the rocker cover breather  (connected to inlet) once engine warm?
and the 3 sensors on the end off the clock from rear to front what are they? and what color cables should be on them?
Reply #4July 17, 2007, 12:39:11 pm
rubadubdub
  • 109
cold start problem
« Reply #4 on: July 17, 2007, 12:39:11 pm »
Nice patchwork mk1, i like it. No idea whats wrong with it i'm afraid!
1991 Mk2 Golf GTD
Reply #5July 17, 2007, 12:47:39 pm
bert
  • 423
cold start problem
« Reply #5 on: July 17, 2007, 12:47:39 pm »
Smoke out the breather tube is normal,dont worry,i would put a splash guard under the rocker cover if there isnt one though,
The sensors are coolant,one goes to dash to do the gauge,the other is for the glow plug relay,so when the engine is hot the glow plugs dont activate,its pissing down here so if you think im going outside now YOUR WRONG  :lol:  will look tom
Bert
Reply #6July 17, 2007, 12:58:45 pm
rov716y
  • 96
cold start problem
« Reply #6 on: July 17, 2007, 12:58:45 pm »
dash temp gauge don't work  (light flashes for a couple off secs when i turn key but thats all)prob got on wrong one i know thats the red and yellow one. the coil light on the dash dont work either and i guess other for oil?
Reply #7July 17, 2007, 12:59:40 pm
rov716y
  • 96
cold start problem
« Reply #7 on: July 17, 2007, 12:59:40 pm »
Quote from: "rubadubdub"
 i guess u been through my photo bucket album lol and no comments about my wife
Reply #8July 17, 2007, 02:22:06 pm
rubadubdub
  • 109
cold start problem
« Reply #8 on: July 17, 2007, 02:22:06 pm »
I didnt pry at all, just looked at the car. My girlfriend started grumbling about how much time i'm on the internet long before i had the chance  :)
1991 Mk2 Golf GTD
Reply #9July 18, 2007, 01:22:55 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
cold start problem
« Reply #9 on: July 18, 2007, 01:22:55 am »
I had a similar starting problem with my MK2 GTD
Turns out theres a plastic housing for the reduction gearbox in the diesel starter motor, turns out mine had shattered into 5 pieces :?
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #10July 18, 2007, 09:08:01 am
rov716y
  • 96
cold start problem
« Reply #10 on: July 18, 2007, 09:08:01 am »
one and all i have sorted it lol
you'll laugh
it was the sensor i had the wrong cable on it lol now starts on the button every time
Reply #11July 19, 2007, 09:59:33 am
rov716y
  • 96
cold start problem
« Reply #11 on: July 19, 2007, 09:59:33 am »
ok once again this mornin wouldn't start so i removed glow plug cable off the fuse in the engine bay connected to battery and she started straight away
so i'm thinking something to do with the coil light not coming on on the dash  but definatly beyond my knowledge off the car
