Author Topic: Normal smoke or a problem  (Read 2203 times)
July 17, 2007, 07:26:55 am
« on: July 17, 2007, 07:26:55 am »
I know most of you will not have driven like this, but hopefully will know the answer. I recently drove up Mt Antero, a jeep trail going to 13500' or so. On the way down, basically engine braking was controlling my speed, with some occasional throttle to increase the speed of the engine braking. During this throttle, I would get whiteish grey smoke, looking like unburnt diesel to me. Would this be from the engine getting so cool? EGT's were reading 0. It seemed ok back on the highway, but if this is a sign that something is starting to happen, I'd rather jump on it now then wait until it gets bad.
Reply #1July 17, 2007, 08:05:35 am
QuickTD
  • 1156
« Reply #1 on: July 17, 2007, 08:05:35 am »
Your diagnosis sounds pretty likely to me. The pump governor will cut off fuel completely on overrun, so your momentary applications of throttle would be effectively restarting the cool engine without glow plugs and at a high altitude to boot, sort of a worst case scenario. You would expect to see some start-up smoke under these conditions. I doubt anything is wrong.
(Edit) Another cause of smoke could be the turbo. Under no-boost conditions there is really nothing to prevent oil from leaking into the compressor housing, there are really no "seals" in the turbo, just mechanical flingers or labrynths. Without positive pressure in the compressor some oil can make its way into the housing and burn off when you gas it again. Again, not really a problem, just a condition unique to your very long low power run. If the exhaust smelled strongly of oil then this would be the likely cause.
Reply #2July 17, 2007, 02:25:24 pm
foxracer1
  • 991
« Reply #2 on: July 17, 2007, 02:25:24 pm »
That is a beautiful view.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #3July 17, 2007, 02:56:20 pm
« Reply #3 on: July 17, 2007, 02:56:20 pm »
now that i've changed to a 160F (coldest you can get at c-tire anyways) i would notice white smoke, whereas i would not before with the 87C t-stat.  since it is much colder the higher you go, i would think that it is improperly burnt fuel.
