QuickTD
I'm there, all but the intercooler. They don't do much at 2mph.
will a TDI exhaust manifold bolt up directly to a 1.6TD head. because arent the TDI variable vane turbos integrated into the ex. manifold?
Well I think that the k03 in sequence with a k24/k26hybrid, or straight k26. Sounds about right :twisted: I am looking for a holset hy35w with the 9cm housing off a 01' dodge with an auto. For a scavenger for my 1.6TD garrett :shock: , I think that should probably give me enough turbo to compress a giles pump
There was a post on the old forum on this, very informative - I found it here:
http://www.hostboard.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4037&t=171Answer is that yes, looks like the variable-vane turbo would fit on an A1. Looks like the main trick would be adapting the VNT controller to work on a non-ECU (mechanically controled) motor.
