1.9 TD pump?
Topic: 1.9 TD pump? (Read 2062 times)
July 16, 2007, 04:51:18 pm
catmanaz
Newbie
1.9 TD pump?
July 16, 2007, 04:51:18 pm »
Hello, new AAZ owner her.
I am curious about my rebuilt 1.9 TD pump. It appears to be missing the manifold pressure line on the top of the pump. It is obvious someone has made a piece to cover the top. Is this a common mod? If not how would this affect the pump performance. Would the same part off a 1.6 pump work? Thanks for any help. Hope that makes sense, still figuring out what everything is called.
James
July 16, 2007, 04:59:25 pm
madmatt
User+
1.9 TD pump?
July 16, 2007, 04:59:25 pm »
if there is no pressure input thr lda will be inoperable so no extra fuel under boost.also looking at the picture i see no secondary water pump that was put on all td t3/vanagons.
t3(vanagon)single cab, upright 1y
t3van aaz
t3 tdi
July 16, 2007, 05:32:31 pm
commuter boy
1.9 TD pump?
July 16, 2007, 05:32:31 pm »
A lot of them came from the factory that way, called "umwelts". If you take the cover off and look inside you'll just see a hollow chamber sealed off from the rest of the pump if it's one of those.
1.9 TD pump?
