Author Topic: hydro vs. mechanical camshaft.....  (Read 5107 times)
July 15, 2007, 07:02:13 am
jimbote
  • 168
« on: July 15, 2007, 07:02:13 am »
what is the difference between a hydraulic and mechanical camshaft in the IDI engines....I have a good mechanical cam out of an 85 1.6 head ....was wondering if I could use it in my 1.9 IDI ?.....
Reply #1July 16, 2007, 01:56:32 pm
« Reply #1 on: July 16, 2007, 01:56:32 pm »
I dont know if you can use a Mech cam in a Hydro head.
I've heard of using a NA hydro cam in a TD hydro head however.
Just check your clearances on the bearing surfaces, they cant be that much differant being the same base engine.
I'm sure if I'm off at all somone will chime in.
Reply #2July 16, 2007, 03:03:33 pm
Black Smokin' Diesel
  • 656
« Reply #2 on: July 16, 2007, 03:03:33 pm »
It has more to do with clearance between the lifters than the bore of the bearing surfaces.
Hydro cams are the same for NA, TD, ECO and even the 1.9TD.
Reply #3July 16, 2007, 03:45:41 pm
« Reply #3 on: July 16, 2007, 03:45:41 pm »
as in they are all interchangeable, or that they are are all the same spec?
Reply #4July 16, 2007, 04:38:06 pm
jimbote
  • 168
« Reply #4 on: July 16, 2007, 04:38:06 pm »
I'm going to get out the calipers and the dial indicator and check these out....I have a 1.6 hydro cam with the pulley taper broken off (scrapyard eco turbo diesel) and I have an 85 mech motor.....maybe I cam come up with something interesting..... :)
Reply #5July 16, 2007, 05:22:30 pm
  • 656
« Reply #5 on: July 16, 2007, 05:22:30 pm »
Quote from: "Trev0rbr"
All interchangeable.
Reply #6July 17, 2007, 11:46:19 am
« Reply #6 on: July 17, 2007, 11:46:19 am »
Quote from: "Black Smokin' Diesel"
What?
You can adjust the clearance between the cam and lifter's you cannot adjust the bearing clearance on the head without machining.
If you have either to much clearance or to little your gonna have problems.
Reply #7July 17, 2007, 03:26:28 pm
  • 656
« Reply #7 on: July 17, 2007, 03:26:28 pm »
Quote from: "zukgod1"
What?
Sorry that came out wrong.
The hydro and solid cams don't have the same lobe profile (clearance between the cam and lifters). They probably have the same bearing surface bore.
Anyway has anyone even ever tried on solid cam on an hydro head and vice-versa?
Reply #8July 18, 2007, 01:05:29 am
Audi80
« Reply #8 on: July 18, 2007, 01:05:29 am »
Hydro cam with solid lifters won´t work, too much valve lash... Have not tried vice-versa.
Reply #9July 22, 2007, 12:06:33 am
Fisher
  • 148
« Reply #9 on: July 22, 2007, 12:06:33 am »
I just fired up a rebuilt 86 Hydraulic Engine with an early Mechanical Cam, works fine, it's the same.
Reply #10July 22, 2007, 09:14:12 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #10 on: July 22, 2007, 09:14:12 am »
Quote from: "Audi80"
Using this info I would easily guess that vice-versa would yield not enough lash. But then again...I suppose lash is set by the hydraulic lifter.
Bah...just go hydro...who wants to mess with valve lash all the time.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #11July 22, 2007, 11:23:49 am
  • 656
« Reply #11 on: July 22, 2007, 11:23:49 am »
So there's too much clearance between the cam lobe and lifter. Does it mean that the solid cam in an hydro would mean more lift?
Reply #12July 22, 2007, 01:45:55 pm
Fisher
  • 148
« Reply #12 on: July 22, 2007, 01:45:55 pm »
No, it means they're the same Cam.
Reply #13July 22, 2007, 01:53:01 pm
  • 656
« Reply #13 on: July 22, 2007, 01:53:01 pm »
Quote from: "Fisher"
Did you compare the two of them? It's not because it works that it's the same cam profile.
Reply #14October 24, 2007, 03:28:45 pm
« Reply #14 on: October 24, 2007, 03:28:45 pm »
so will a hydro cam work on a solid lifter engine? I broke mine and have found a cheap hydro cam that I might buy. thanks
