Author Topic: FS: Injection Pump, 90 Jetta  (Read 3639 times)
July 13, 2007, 06:06:14 am
coke
  • 254
« on: July 13, 2007, 06:06:14 am »
I have an injection pump I took off my 90 Jetta Diesel 1.6L NA. It has the idle boost and the ADA on top of the pump (altitude compensation)
It worked when removed from the car. I swapped it out because I thought it had a problem but the pump I put on didn't change the problem, turned out to be low compression. It'll need the check valves swapped in from another pump or have them replaced. Its also missing one of the copper washers that seal the inlet and outlet of the pump. I had to rob one when I lost one.
Pump estimated to have about 250k miles on it.  Never failed me, and I noticed no leaks at all.  Im open to offers, pm/email. Thanks in advance!
