Author Topic: How much PSI without blowing the engine?  (Read 2441 times)
July 12, 2007, 11:18:43 am
Bojje
  • 25
« on: July 12, 2007, 11:18:43 am »
Hello!
As the topic says I'd like to know how much boost the engine can take safely. The engine: 1,9TD.
Thanks  :D
Reply #1July 12, 2007, 01:59:46 pm
subsonic
  • 1836
« Reply #1 on: July 12, 2007, 01:59:46 pm »
Is your engine stock, or does it have modifications?  There can be a very big difference depending on your answer.
Reply #2July 12, 2007, 03:27:56 pm
hillfolk'r
  • 1532
« Reply #2 on: July 12, 2007, 03:27:56 pm »
i wouldnt push more than 20-25 psi if its stock
if you put in head studs,it helps
i used to let my old 1.6td go to 40 psi with studs
its not really the boost that will "blow it up",its the amount of fuel
i used to go 40 psi with the stock 9mm inj. pump,but when i did it with the 12mm pump i installed later on ,i started popping head gaskets
Throttle cables ftw
Reply #3July 13, 2007, 07:28:46 pm
somolovitch3
  • 290
« Reply #3 on: July 13, 2007, 07:28:46 pm »
Sounds like Brighten Torque...........
"Torque it up untill it breaks, ....  Then back it off a 1/4 turn..."  :roll:
After replacing all the "used a bigger hammer, becaused it didn't work anyway' stuff, back the boost down a 1/4 psi.
you will find the perfit match between your walet and your need for........"OMG...What have I done?......"
Enjoy!   :twisted:
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
