Author Topic: EGT gauge - pre or post turbo?  (Read 3108 times)
January 31, 2005, 05:46:41 am
mk1vdub
  • 93
« on: January 31, 2005, 05:46:41 am »
where is best for optimum readings? where have all you guys got them, and for what reasons? - ease of fitting over reliable readings?
does it make a difference or is it just a case of compensating for slightly higher or lower figures?
I have the option of either and they are no more difficult than each other - which should I go for?
discuss :D
Cheers
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
Reply #1January 31, 2005, 05:56:23 am
QuickTD
  • 1156
« Reply #1 on: January 31, 2005, 05:56:23 am »
I would mount it pre-turbo. No guessing or calculating then, you get the actual temperature and the response is very fast. Some people will say it's risky if the probe breaks, but nobody has ever actually seen this happen. I would drill and tap through the boss in the manifold directly under the turbo. This will locate the probe nice and centered in the exhaust stream.
