Author Topic: fuel leak...  (Read 8192 times)
May 26, 2004, 02:36:42 pm
RevelationX
  • 11
fuel leak...
« on: May 26, 2004, 02:36:42 pm »
Hey folks...Me again....I noticed this afternoon that I have a "slight" leak from a fuel line on top of the fuel dist/pump...coming off what looks like a banjo bolt marked "OUT" on top..Is this a high press. line? can I use some sort of normal hose clamp? or does it need to be something special ?
Thanks
Keith
Power hath decended forth from thy hand
so our feet may swiftly carry out thy command.
And we shall flow a river forth to thee
and teeming with souls shall it ever be....
Inomine Patris,et Filii,etSpiritus Sancti.
Reply #1May 26, 2004, 05:23:57 pm
fspGTD
  • 1529
fuel leak...
« Reply #1 on: May 26, 2004, 05:23:57 pm »
Nope, that is low pressure, fuel return line (returns fuel back to the tank.)  There are 2 hoses that connect to the out banjo: one little one that connects to the injector return line, and a big one that returns fuel back to the tank.  This fuel line eventually decays with time and heat and should be replaced if it gets brittle.  I recommend using the OEM cloth-braided stuff, both are available aftermarket from OEM VW suppliers.  The cloth-braided fuel return line has a 7mm inside diameter.
Jake Russell
Reply #2May 27, 2004, 01:51:38 pm
RevelationX
  • 11
fuel leak...
« Reply #2 on: May 27, 2004, 01:51:38 pm »
Thats what I was wanting to hear...I tell ya...you guys are super.. :)
Thanks a bunch..
Keith
