Author Topic: Gear ratio information?  (Read 3640 times)
July 06, 2007, 06:52:49 am
Infinitrium
  • 151
« on: July 06, 2007, 06:52:49 am »
Does anyone have the gear ratios for the 93 Jetta with the stock 5 speed and  the AAZ engine? Since my Jetta doesn't have a tach, if I had the gear ratios I could do a little calculation and I'd be able to figure out how many rpm's the engine is turning at any given speed for each gear.
Reply #1July 06, 2007, 07:29:23 am
« Reply #1 on: July 06, 2007, 07:29:23 am »
www.scirocco.org/gears
There are different trannys used, climb under the front of the car and look on the bellhousing for the code
Reply #2July 06, 2007, 12:19:44 pm
Infinitrium
  • 151
« Reply #2 on: July 06, 2007, 12:19:44 pm »
Found it. The tag says CHD07082. So I guess that means I have the 3.67 final drive.
Reply #3July 07, 2007, 05:28:50 am
« Reply #3 on: July 07, 2007, 05:28:50 am »
You're correct. You have a nice one
