Author Topic: what are you guys doing for a breather setup  (Read 9519 times)
July 05, 2007, 04:39:51 pm
Justin
  • 455
« on: July 05, 2007, 04:39:51 pm »
like the title says what are you doing for a Turbo Crankcase setup?
I have a TDI with the breather thing for the valve cover but I think that I need a breather between that and the crankcase
thanks in advance
later
Justin
www.archeryprostaffmi.com
Reply #1July 05, 2007, 05:50:29 pm
« Reply #1 on: July 05, 2007, 05:50:29 pm »
I'm all stock. It seems to work just fine for a healthy (and even not so healthy) engine
Reply #2July 05, 2007, 06:29:09 pm
Justin
  • 455
« Reply #2 on: July 05, 2007, 06:29:09 pm »
what is stock exactly? I ran the hose from the crankcase to the breather deal on top of the valve cover, when I shut the engine off I can hear the pressure slowly releasing and I think that I need to let the crankcase breath more
Reply #3July 05, 2007, 07:29:35 pm
« Reply #3 on: July 05, 2007, 07:29:35 pm »
Stock is from the top of the VC to the intake hose
Reply #4July 05, 2007, 08:34:22 pm
Justin
  • 455
« Reply #4 on: July 05, 2007, 08:34:22 pm »
so I need to run a line to my intake,
thanks
Justin
Reply #5July 06, 2007, 06:33:24 pm
« Reply #5 on: July 06, 2007, 06:33:24 pm »
birch beer ftw
Reply #6July 07, 2007, 06:43:39 am
Spothead
  • 7
« Reply #6 on: July 07, 2007, 06:43:39 am »
I must have an unhealthy engine, it's got 188,000 miles on it.  When I attach a hose from my valve cover to the intake plenum it blows my oil dipstick tube out and starts to spew oil. So I ran a hose from the valve cover to the back of the car.  I have more smoke coming out of the tube than I do the exhaust.  Is their anything I can do  or should I just run it.
91 Jetta 225,000 miles
85 Golf engine 188,000 miles N/A
running on veggie oil and Biodiesel
Reply #7July 08, 2007, 05:52:44 pm
« Reply #7 on: July 08, 2007, 05:52:44 pm »
Quote from: "Spothead"
that car needs attention haha
Reply #8July 08, 2007, 08:18:32 pm
« Reply #8 on: July 08, 2007, 08:18:32 pm »
yeah it sounds like the rings are kaput. Do a compression test
Reply #9July 09, 2007, 12:13:45 am
  • 2931
« Reply #9 on: July 09, 2007, 12:13:45 am »
 Sounds like an A2 NA.
 Did I guess right?
 If so drill out the restrictors in the intake manifold.
Reply #10July 11, 2007, 03:25:17 pm
Spothead
  • 7
« Reply #10 on: July 11, 2007, 03:25:17 pm »
Yes, I put my car in my sig but it's not showing on screen.  91 jetta NA with a 85 golf na solid lifter engine.  The car gets up and goes ok I can do 75 80 on the highway and pulls uphill pretty good. Probally needs rings huh.
Reply #11July 11, 2007, 03:26:03 pm
Spothead
  • 7
« Reply #11 on: July 11, 2007, 03:26:03 pm »
Well I guess it shows up now
Reply #12July 11, 2007, 03:35:15 pm
hillfolk'r
  • 1532
« Reply #12 on: July 11, 2007, 03:35:15 pm »
yep i got a hose from the lower crankcase to the top valve on the cover,sorta like stock,just different  plumbing,i couldnt use the factory lower hose,so i used that clear braded vinyl home depot hose,like 1.25 inch
i got a tdi(m) too....
then i ran a 3/4 inch hose out into the left wheelwell near the steering rack
since i got totalseal rings(lol) i dont smell nasty fumes
Throttle cables ftw
Reply #13July 11, 2007, 03:58:37 pm
Spothead
  • 7
« Reply #13 on: July 11, 2007, 03:58:37 pm »
The vent on the crankcase must be a Turbo Diesel thing cause there isn't one on my NA
Reply #14July 11, 2007, 05:25:41 pm
Chestrockwell
  • 95
« Reply #14 on: July 11, 2007, 05:25:41 pm »
My 97 TD has the lower crankcase vent which I covered and just run a piece of hose from the valve cover and it hangs down by the steering rack. No oil dots on the back of the car. No oil in the intake.
