Author Topic: omnivalves-anti reversion intake valves  (Read 6311 times)
July 04, 2007, 08:52:34 pm
CoolAirVw
  • 175
« on: July 04, 2007, 08:52:34 pm »
I did a search and found no thread discussing these.
Lets replace our intake valves with some of these!
(Before flaming me and bashing these valves read the thread from speedtalk.com.  There are some hardcore guys and they bashed the valves to death, then the developer of the valve Mike Tieman (tieman55) came onto the forum and answered their questions and it seemed to me he made them believers or at least opened thier minds to it a little bit.
Here's the most interesting discussion of the valves.
http://speedtalk.com/forum/viewtopic.php?t=4374
Here is their website.
http://www.omnivalves.com
Here Jake Raby of Air Cooled Technology was given some to test (no results yet)
http://forums.aircooledtechnology.com/showthread.php?t=411
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #1July 04, 2007, 08:59:22 pm
hillfolk'r
  • 1532
« Reply #1 on: July 04, 2007, 08:59:22 pm »
i use these
they are so big,you can use one per cylinder,and let them do double duty :lol:
yes that is a stock 1.6 piston
they are so big,they dont even fit in the cyl
the stem is like 9/16
i also use these wristpins for pistons
 :lol:
thats because of this
WOLFGANG WILL KICK DR.Z'S ARSE ANY DAY OF THE WEEK!!!!!!!!
Throttle cables ftw
Reply #2July 05, 2007, 09:32:56 am
« Reply #2 on: July 05, 2007, 09:32:56 am »
:lol:
if these are as good as they say they are, they must cost an arm and a leg
Reply #3July 05, 2007, 02:23:22 pm
foxracer1
  • 991
« Reply #3 on: July 05, 2007, 02:23:22 pm »
VEE DUB in da house!!
love those comercials
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4July 05, 2007, 03:24:23 pm
Turbinepowered
  • 1206
« Reply #4 on: July 05, 2007, 03:24:23 pm »
So basically they put a ring-shaped reed-type valve on the valve stem of the intake valves, and are hailing it as an enormous breakthrough?
I dunno... I mean, for an otto cycle, that has some valve overlap, I could see this being a good thing, but for a diesel not nearly such a huge development since the lack of overlap means that exhaust gas can't push backwards into the intake.
Also, the author seems to be ignoring the fact that there are other ways  to open, and more importantly close, valves much more precisely and quickly, namely through desmodromic valvetrains. And desmodromic, coupled with VVT and VCT technologies could provide both differences in valve open/closure speeds and timing, with much more precision than a floating, air pressure controlled device within the valve itself.
Reply #5July 05, 2007, 03:51:39 pm
Northern RD
  • 167
« Reply #5 on: July 05, 2007, 03:51:39 pm »
Quote from: "Turbinepowered"
Good Lord, another Ducati lover,...
Reply #6July 05, 2007, 07:54:29 pm
Turbinepowered
  • 1206
« Reply #6 on: July 05, 2007, 07:54:29 pm »
Quote from: "Northern RD"
Ducati lover, me? Not really. I'm not into the whole "I have to go as fast as I can" thing that seems to be the lure of Ducati.
No, I just like the technology. It's precise, it's efficient, and it's incredibly complex while at the same time being absurdly simple. It solves at least one problem and allows for more variability with relation to valve timing, so what is there to dislike?
Reply #7July 06, 2007, 10:14:02 am
Northern RD
  • 167
« Reply #7 on: July 06, 2007, 10:14:02 am »
What`s not to dislike??
Well, having lived with a 900SS for three years I can honestly say that during the 2% of the time that the duck was running well, it was a dream: the other 98% of the time it had all the tractability and grace of a garbage truck as a daily ride. After some 37,000km I got fed up with the constant tinkering and sold it to someone who paid me a Kings ransom. By way of comparison, the `85 FZ750 beater that I use a daily ride has over 108,000km on the clock, has never needed a valve lash since I purchased it at 22,000km, and is STILL within correct valve spec. It`s a better bike in ever MEASURABLE way(discounting immesurables like 'mystique', 'heritage', etc) and doesn`t require half the effort to maintain. Put more simply, the FZ750 allows me more riding time than the Ducati wheras the Ducati demands WAY more screw driver time for the little it gave in return.
My 2 cents,...
Apologies, meant to say '-like', not 'dislike',...
Reply #8July 06, 2007, 10:35:30 am
Turbinepowered
  • 1206
« Reply #8 on: July 06, 2007, 10:35:30 am »
Can't really say that I can vouch for Ducati durability and driveability; I don't own one, don't own a motorized bike at all (though I do have almost 2k miles on my bicycle). But I honestly can't believe that all of that wrenching time was caused by the desmodromic valve system. Maybe I'm wrong, but I just find it hard to believe.
Reply #9July 09, 2007, 10:29:44 am
Northern RD
  • 167
« Reply #9 on: July 09, 2007, 10:29:44 am »
Unfortunatly the Desmos` advatages are more appant than real. Take for example the fact that one of the designs adavantages is that it manages to avoid the vicious spiral between inreased lobe lift and increased valve spring pressure. Desmo advocates make a point of mentioning this but fail to explian how this is an advantage in the real world as an increase in cam duration almost always leads to increased power at the upper end of the power band, usually at a speed beyond that which the rocker set-up in a desmo can fallow without catastrophic binding. Cagiva managed to side-step this nicly by using simply, low-tech OHC in thier v-twins and they`ll rev reliably well beyond what a duck would(I`mm sure someone out there will argue this!).
As well the Ducati calls for a valve lash something like every 15-17,000km with the desmo valve train wheras the FZ750 I mentioned above scheduals it`s first valve spec check at 100,000KM, that with it`s low tech shim and bucket system.
N.
Reply #10July 09, 2007, 10:31:30 am
Northern RD
  • 167
« Reply #10 on: July 09, 2007, 10:31:30 am »
Almost forgot: 2,000 miles on the bike? Good stuff, keep it up!
N.
Reply #11July 09, 2007, 06:15:37 pm
CoolAirVw
  • 175
« Reply #11 on: July 09, 2007, 06:15:37 pm »
Wow.  This thread is the king of the hijack.
7 posts about Ducati's, 1 post about VW commercials and 1 post with non-sense pictures (very funny though)
Oh well.   :roll:
Hey at least explain this comment.  (or maybe a link I could read)
...... namely through desmodromic valvetrains. And desmodromic, coupled with VVT and VCT technologies could provide both differences in valve open/closure speeds and timing, with much more precision than a floating, air pressure controlled device within the valve itself.
Oh, nevermind I Googled it, http://www.teamyikes.com/desmo.html
75 Porsche 914
93 GMC Truck
Reply #12July 09, 2007, 06:51:18 pm
935racer
« Reply #12 on: July 09, 2007, 06:51:18 pm »
I'd definitely be interested in hearing some 3rd party results.
Reply #13July 10, 2007, 07:29:35 am
« Reply #13 on: July 10, 2007, 07:29:35 am »
Well, the site is hard to read and full of typos, but they dynoed a built LS1 engine and it made 440 ft/lbs of torque at 1500 rpm, which I find really hard to believe.  Apparently they are getting engines to idle at 200 rpm and make torque at that speed.  Sounds neat but I'd like to see it to believe it.  They also said in the site they are testing a Cummins 6BT engine (they spelled Cummins wrong BTW) but testing is not complete.  I am curious, that's for sure.
Reply #14July 11, 2007, 05:35:40 pm
Chestrockwell
  • 95
« Reply #14 on: July 11, 2007, 05:35:40 pm »
Sounds like they're desparately trying to replicate an electric motor.
