For Sale/Looking For
Parts for Sale/Wanted
FS: complete 1.9TD block
Topic: FS: complete 1.9TD block (Read 5083 times)
July 02, 2007, 07:30:40 am
July 02, 2007, 07:30:40 am »
block has ~300k kms on it
I was told that the timing belt jumped. The guy I got it off of tried to retime it but couldn't figure it out. He did not try and start it. I retimed it and it started up just fine.
When I took the engine apart there appears to be no valve/piston contact. The crank pulley feels firm but I have ot removed it to inspect it
$200 OBO
delivery can be arranged (within reason)
Will ship
July 02, 2007, 08:42:53 pm
blkboostedtruck
July 02, 2007, 08:42:53 pm »
Hi tyler,
what does this consist of ? just a block? crank? head?sounds like a complete motor when you say no evidence of piston and valve contact! am i hearing you right or reading you wrong ? thanks Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
July 02, 2007, 08:45:39 pm
July 02, 2007, 08:45:39 pm »
Hi Duane
It's just the bottom end. pan, crank, pistons, rods and block
July 02, 2007, 08:55:15 pm
blkboostedtruck
July 02, 2007, 08:55:15 pm »
really :lol:
do you know anything about using a 1.6 head on it? I heard it can be done but thats all i know? tell me what you know about this ol' wise one :idea: !
and what is the break down on miles from metric to miles on it ? thanks Duane
'66 variant 1500S
July 03, 2007, 07:03:11 am
July 03, 2007, 07:03:11 am »
Well if you can use a 1.9 head on a 1.6 with lower resulting compression, then I'd imagine a 1.6 head would raise compression a bit on a 1.9.
July 03, 2007, 08:19:02 am
July 03, 2007, 08:19:02 am »
180 000miles
It will bolt right on but as mentioned your CR will go up.
You could machine your pistons or something to lower the CR
July 05, 2007, 04:28:43 am
somolovitch3
July 05, 2007, 04:28:43 am »
What size pistons are in the block? Standard, 1st over, ....?
Still working on getting stuff past the US/CN line. :evil:
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
July 05, 2007, 05:10:52 am
July 05, 2007, 05:10:52 am »
I never checked. My guess is stock but I'll have a look next time I'm there.
What is stock size btw?
July 06, 2007, 04:22:33 am
somolovitch3
July 06, 2007, 04:22:33 am »
STD should be stamped on piston tops. 76.5 mm.
1st oversize is .25, 2nd .50, all the way up to 4th oversize at 1.00.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
July 06, 2007, 07:34:31 am
July 06, 2007, 07:34:31 am »
Thanks
