Author Topic: A-1 (1981 Jetta) suspension Question  (Read 3431 times)
June 28, 2007, 02:28:54 pm
HermTDI
  • 27
« on: June 28, 2007, 02:28:54 pm »
I have a friend that owns an A-1 Jetta and is in need of suspension maintenance.
After looking at parts availability I have a question conserning the front struts.
It looks like the  strut "insert" is replaceable. My question is about these inserts. What are they talking about when listing replacement inserts...with "INSIDE THREADS" and "OUTSAIDE THREADS".
Which inserts do I need...and how do I make this determination.
Thanks in advance.
Herm
Reply #1June 29, 2007, 05:42:03 am
FineFrank
  • 72
« Reply #1 on: June 29, 2007, 05:42:03 am »
Easy. Jack up the front of the car (unless your hands are smaller than mine) and push up the strut boot with your fingers until you can see the top of the strut housing. You'll be able to see a nut on the top; if it screws ONTO the housing, you'll need cartridges for external threads: if it screws INTO the housing, you'll need cartridges for internal threads.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants"   -Albert Camus-
Reply #2June 29, 2007, 11:01:30 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #2 on: June 29, 2007, 11:01:30 am »
I just did the struts on my 86 Golf,  and found that the complete strut assembly was actually cheaper than the strut inserts.  (Monroe Sensatracs versus an aftermarket OEM replacement insert.)
Calvin
91 VW Golf 1.6NA 5spd
