Author Topic: Would 11mm size bolts head fit on a 12mm block??  (Read 3694 times)
June 27, 2007, 09:51:12 pm
rabbit_diesel
  • 44
    • http://www.vwvortex.com
« on: June 27, 2007, 09:51:12 pm »
I found a cylinder head for my 1.6 N/A block.  It turns out that it is an 11mm head and I was wondering if I could some how make the 12mm bolts fit.  The bolt holes are just a bit too small would it work to drill them larger?   If so, how much larger should they be compared to the bolts?
i'm dubbin it
Reply #1June 28, 2007, 05:46:09 am
saurkraut
  • 904
« Reply #1 on: June 28, 2007, 05:46:09 am »
I'd be concerned about the compression ratio.  Its probably a 1.5 head, which would have smaller swirl chambers.  If you put it on a 1.6, your compression ratio will be higher, and thats not a good thing.  By my rough calculation, the CR would be 25.3:1.
Does the Thorpedo still exist?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2June 28, 2007, 07:26:55 am
myke_w
  • 1099
« Reply #2 on: June 28, 2007, 07:26:55 am »
I've done it, works like a charm as long as it's a 1.6 head.
Just drill out the bolt holes with a large enough bit and do it with a drill press NOT WITH A HAND DRILL.
You'll need 12 mm bolts, and an extra 11mm head bolt washer per bolt.
The way to tell if if it's a 1.6 or 1.5 is the size of the oil drain bump on the front middle of the head.
small = 1.5
large (like your old one) = 1.6
Reply #3June 28, 2007, 08:35:54 am
rabbit_diesel
  • 44
« Reply #3 on: June 28, 2007, 08:35:54 am »
Yes, I am sure it's from a 1.6 block.  I'll make sure that I get them straight.  So I will need two washers per bolt?
i'm dubbin it
Reply #4June 28, 2007, 10:51:43 am
myke_w
  • 1099
« Reply #4 on: June 28, 2007, 10:51:43 am »
correct, 2 washers per bolt, you may need to grind the edges to get them to fit too.  Let  us know how it turns out.
Reply #5June 28, 2007, 07:22:11 pm
tylernt
  • 344
'82 Diesel Rabbit, '88 Fox RIP, '88 Jetta (work in progress)
Reply #6June 28, 2007, 07:47:02 pm
rabbit_diesel
  • 44
« Reply #6 on: June 28, 2007, 07:47:02 pm »
Thanks Tylernt, that is good information! Especially on this Exact topic.  :wink:
i'm dubbin it
Reply #7June 29, 2007, 11:29:17 am
rabbit_diesel
  • 44
« Reply #7 on: June 29, 2007, 11:29:17 am »
Quote from: saurkraut
Yes, it is still around.  I was actually thinking of getting their vegetable oil to run in my jetta :lol: .  Have you ever been there?
i'm dubbin it
