Author Topic: Have a question about Eco-D.  (Read 8215 times)
May 26, 2004, 09:21:42 am
jacoblawler
« on: May 26, 2004, 09:21:42 am »
I am not new to vws by any means but I am new to diesels.  My dad wrecked his 91 Eco-Diesel and thinking about putting it in my 90 Jetta.  I know the swap wont be hard it is about the engine I am concerned about.  I know if has no fuel enrichment (which maybe someone could elaborate how it works on a diesel) and a smaller turbo.  So I was wondering if I was not only looking for better gas mileage would it be worth putting this motor in because I wanted an engine that I could "toy" around with some.  Thanks.
Reply #1May 26, 2004, 09:46:51 am
BlackTieTD
  • 1512
« Reply #1 on: May 26, 2004, 09:46:51 am »
you could always put on a bigger turbo and a proper turbo diesel injection pump...and whatever else you'd need to make it a proper TD.
the eco-diesel is a good place to start... its free right?
i'd throw it in and swap the proper 'go fast' TD parts down the road.
Reply #2May 26, 2004, 11:22:15 am
Spike_TDI
  • 50
« Reply #2 on: May 26, 2004, 11:22:15 am »
I'm sure that the Eco and TD use the same K03 turbo. All you need is the injection pump. PM me I have one forsale.
Reply #3May 26, 2004, 09:47:33 pm
dieselpower
  • 177
« Reply #3 on: May 26, 2004, 09:47:33 pm »
I thought the TD had a k24 turbo not the K03.
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #4May 27, 2004, 12:07:38 am
VWRacer
  • 649
« Reply #4 on: May 27, 2004, 12:07:38 am »
My '85 Quantum 1.6 TD has a K24 turbo.
Stan
C-Sports Racer
Reply #5May 27, 2004, 07:33:03 am
BlackTieTD
  • 1512
« Reply #5 on: May 27, 2004, 07:33:03 am »
so its easy to bring it up to TD level then.. fit an injection pump with the boost aneroid and you're set... or if you can get just the aneroid, you can fit that to your existing NA pump. see where you stand after that.  :D
Reply #6May 27, 2004, 07:52:55 pm
Rat407
  • 289
« Reply #6 on: May 27, 2004, 07:52:55 pm »
If I'm reading my data plate right my Eco diesel has a K14 turbo.  Would it really be worth the swap of the injection pump from an eco to a regular TD? Is there really that much of a difference?
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #7May 28, 2004, 11:42:27 am
BlackTieTD
  • 1512
« Reply #7 on: May 28, 2004, 11:42:27 am »
Quote from: "Rat407"
eco has a turbo to be fuel efficient
TD has a turbo to be fast(er)
thats a broad statement but its basically true.
yes, the TD pump will yield a significant performance increase over your eco pump. the eco pump AFAIK does not have a boost aneroid, which is what senses the turbo making boost, and it adds extra fuel, which means more power. no boost aneroid, no extra fuel/power... just better economy.
Reply #8May 28, 2004, 12:03:53 pm
DieselsRcool
  • 152
« Reply #8 on: May 28, 2004, 12:03:53 pm »
Seems I remember reading somewhere that the turbo was used on eco-diesel primarily to eliminate smoke. Hard to beat the mpg of the NA. Does the eco-diesel get better mpg? I was also under the impression that the name implies Eco-friendly as in less visible polution. Maybe both, eco-friendly and eco-nomical.  :)
Reply #9May 29, 2004, 08:03:31 pm
AntonUK
« Reply #9 on: May 29, 2004, 08:03:31 pm »
I live in the UK as far as i know (and according to documents) i have a 1.9TD but its called an 'umwelt' which translates environment in german. but it does have a boost compensator aneroid on the pump. should i ignore the umwelt name and assume its still the nippy TD? It keeps puzzling me :?
