Author Topic: Joint Flange question  (Read 3810 times)
June 22, 2007, 08:15:57 am
bevboyy
  • 200
« on: June 22, 2007, 08:15:57 am »
I have a EQ 3 speed auto trans w/90mm Joint flanges. The target car is a 92 Jetta gas with 3 speed auto w/100mm axles and joint flanges. Can I use the 100mm flanges on the EQ trans?
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #1June 22, 2007, 08:25:10 am
« Reply #1 on: June 22, 2007, 08:25:10 am »
If you swap flanges on the tranny you should be fine
Reply #2June 22, 2007, 10:30:53 am
bevboyy
  • 200
« Reply #2 on: June 22, 2007, 10:30:53 am »
Thanks Tyler, that's what I thought. I'll do the axle swap as well. Do it now before I drop the engine in...
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
