Author Topic: GTD with AAZ or other Head?  (Read 2178 times)
June 20, 2007, 03:55:40 am
Stanton
  • 18
« on: June 20, 2007, 03:55:40 am »
is this possible....
ran 15psi with a bleed valve and pump mods, was reli good... pulled clean and was great fun, then on the way back from a vw show one of the rad hoses split and pissed coolant, got hot... head cracked....
now im not having much luck gettn a replacement head in the uk... can i use an aaz or other head?
cheers in advance for your help :)
Reply #1June 20, 2007, 04:01:36 am
Audi80
« Reply #1 on: June 20, 2007, 04:01:36 am »
If you canīt get a new head from UK, can you order one from Germany?
Reply #2June 20, 2007, 04:06:31 am
Stanton
  • 18
« Reply #2 on: June 20, 2007, 04:06:31 am »
its more the cost involved too.
Ģ300 for a new head isnt viable right now....
ive got hold of a 1.6TD for Ģ75..... which turbo is it likely to have...t3?
this will go straight on my T2 equipped GTD wont it?
Reply #3June 20, 2007, 07:06:01 pm
« Reply #3 on: June 20, 2007, 07:06:01 pm »
As long as both are hydro or both are solid lifter it will bolt right on.
The exhaust ports/studs are the exact same
Reply #4June 21, 2007, 02:25:41 am
Stanton
  • 18
« Reply #4 on: June 21, 2007, 02:25:41 am »
Quote from: burn_your_money
thankyou for the info mate! 8)
