Author Topic: Cracks between the valves  (Read 5218 times)
January 18, 2005, 12:21:58 pm
Cman
  • 5
« on: January 18, 2005, 12:21:58 pm »
Ok I pulled my head this morning (1994 1.9 TD) and there are small cracks between the valves on all 4 cylinders..   one of them (#1) is noticable larger than the others..
Could this be the source of the exhaust/compression leaking in to the cooling system,, or is it more likely the head gasket. .
I spilled oil all over everything when I removed the head so I really cant tell if the head gasket has been leaking. .
Thanks for the help
Tom
Reply #1January 18, 2005, 09:58:15 pm
MK3 GTD
  • 48
« Reply #1 on: January 18, 2005, 09:58:15 pm »
almost all vw diesels end up with those cracks in the head and they are considered normal to a certain point, as for the coolant issue, you may want to get the head checked by a good machine shop for cracks
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
Reply #2November 09, 2005, 01:27:50 am
Maarten
  • 339
« Reply #2 on: November 09, 2005, 01:27:50 am »
Can these cracks go all the way up to the coolant channel?
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
