Author Topic: My 1992 Ecodiesel is done  (Read 8229 times)
June 17, 2007, 05:45:21 pm
larry104
  • 200
« on: June 17, 2007, 05:45:21 pm »
First, I’d like to thank the people on this board for making it all possible. Through here I hooked up with Giles for the modded pump, Daryl at AA Transaxle for the trans rebuild, and Jack at VW Diesel Parts. This is a great resource and I’ve learned a lot.
Details:
Neuspeed Softsport springs
Koni adjustable shocks
Snowflake rims
GTI grille w/Hella E-code lamps
2.25-in. stainless steel mandrel-bend down pipe and exhaust
Giles pump
GTD nozzles
GTD intercooler with thermostatically controlled fan, handmade air inlet and ducting. (the vice-grip trick I learned here works great for making lips on the tubing!)
Combo EGT/Boost gage
Boost controller -- 15 psi
3.67 ring/pinion, 0.71 5th
Audiovox cruise control
When I bought this car two years ago, it was, in my estimation, dangerously underpowered. Granted, this is my first diesel, and I was used to gassers. But I was determined to make it run better. All I can say is, I am totally impressed with the performance now. Giles trick pump made a HUGE difference. Thank you! The intercooler makes surprising, seat-of-the-pants gains in both torque and top end (I never would have believed it). No doubt the high-flow exhaust is a big factor as well. The added power easily handles the taller gearing. The car is a blast to drive. Thanks again all. :D
http://www.geocities.com/waloo321/P1010400.JPG
http://www.geocities.com/waloo321/P1010395.JPG
http://www.geocities.com/waloo321/P1010393.JPG
http://www.geocities.com/waloo321/P1010390.JPG
Reply #1June 17, 2007, 06:14:06 pm
Black Smokin' Diesel
  • 656
« Reply #1 on: June 17, 2007, 06:14:06 pm »
Beautiful car, digging the GTD intercooler setup. Must be a blast to drive.
91 Passat syncro 1.8T swapped.
Reply #2June 17, 2007, 06:16:45 pm
« Reply #2 on: June 17, 2007, 06:16:45 pm »
Very nice :D
Can you explain the vise grip trick?
Reply #3June 17, 2007, 06:32:35 pm
rallydiesel
  • 1880
« Reply #3 on: June 17, 2007, 06:32:35 pm »
Awesome. So do you have a TD pump? Stock turbo?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4June 17, 2007, 06:34:41 pm
larry104
  • 200
« Reply #4 on: June 17, 2007, 06:34:41 pm »
Quote from: burn_your_money
You'll need a pair of vice grips and a large spike, like 0.125 in. diameter. Grind a circumferential groove in the lower jaw near the end to hold the nail. Bend the nail around and into the groove. Cut off the excess. Grind a mating "die" in the upper jaw to match the nail diameter. Find a suitable stop to keep the depth consistent. I used a miniature hose clamp. Walk the tool around the pipe end with the nail side inside. Clamp, release, etc... Tighten the vice grip a little and do it again. It works well, at least on 0.049-in. 304 aluminum tubing.
Reply #5June 17, 2007, 06:35:26 pm
larry104
  • 200
« Reply #5 on: June 17, 2007, 06:35:26 pm »
Quote from: rallydiesel
Yes, TD pump. Stock K14.
Reply #6June 17, 2007, 09:35:11 pm
« Reply #6 on: June 17, 2007, 09:35:11 pm »
Quote from: "burn_your_money"
Very nice :D
I think there is a thread with pics. I think Named TinTin posted it. I made a pair also, and they work on steel exhaust pipe as well.
Nice job on your car, it looks very well done.
Reply #7June 18, 2007, 10:51:54 am
yankeejim
  • 8
« Reply #7 on: June 18, 2007, 10:51:54 am »
Love it, exactly what I'd like to do with mine some day.
'92 Jetta ECOdiesel
Reply #8June 18, 2007, 08:16:16 pm
jackbombay
  • 599
Re: My 1992 Ecodiesel is done
« Reply #8 on: June 18, 2007, 08:16:16 pm »
Nice ride!
Quote from: "larry104"
  Where did you get the thermal switch? At what temps does it turn/turn off?
Reply #9June 18, 2007, 08:49:34 pm
« Reply #9 on: June 18, 2007, 08:49:34 pm »
rainbow electronics sells a thermostat that opens at 0C - 120C :) pretty cheap too... I have one :)
http://vwdiesel.net/phpBB/viewtopic.php?t=1694&start=0
Jake was the one who had the vice grip trick :) nice pics too!
Reply #10June 18, 2007, 09:38:21 pm
jackbombay
  • 599
« Reply #10 on: June 18, 2007, 09:38:21 pm »
Quote from: "jtanguay"
   Cool, thanks for the tip, I'll call them tomorrow!
Reply #11June 19, 2007, 06:06:43 am
larry104
  • 200
« Reply #11 on: June 19, 2007, 06:06:43 am »
Quote from: jackbombay
Nice ride!
Quote from: larry104
Electronic Surplus. Normally open and closes at 120 deg F. It's attached to the surface of the intercooler at the inlet side.
Reply #12June 19, 2007, 11:22:28 am
jackbombay
  • 599
« Reply #12 on: June 19, 2007, 11:22:28 am »
Quote from: "jackbombay"
  I couldn't find such an item on their website, was it listed under "thermostat" or "thermistor"?
EDIT- Is this the one you used?
Reply #13June 19, 2007, 11:42:01 am
larry104
  • 200
« Reply #13 on: June 19, 2007, 11:42:01 am »
Not everything in their store is on their Website. I'd suggest calling them. It's called a thermal switch. The one I have works either normally open or normally closed (three terminals).  I use it normally open.
Reply #14June 20, 2007, 01:28:05 pm
larry104
  • 200
« Reply #14 on: June 20, 2007, 01:28:05 pm »
jackbombay,
sent you a pm.
larry
