Author Topic: Simple way to remove exhaust clamps?  (Read 12452 times)
June 15, 2007, 07:39:15 pm
rallydiesel
  • 1880
« on: June 15, 2007, 07:39:15 pm »
I am going to be pulling our 1.6 TD's engine for the first time and want to know how you guys remove the C clamps on the down pipe? Could I just use a couple curved rods to lever them open or do I need a special tool?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1June 15, 2007, 07:43:52 pm
Fisher
  • 148
« Reply #1 on: June 15, 2007, 07:43:52 pm »
Getting them off is easy, you can just stick a screw driver into the hole in one end and pry them off, watch your face when you do it.  Getting them back on is the hard part.
Reply #2June 15, 2007, 08:31:04 pm
« Reply #2 on: June 15, 2007, 08:31:04 pm »
For removal I used to pry them off with a ratchet or screwdriver, whatever was handy.
Now I use this
worth it's weight in gold
If you need tips for installation without the tool just ask
Reply #3June 15, 2007, 08:44:10 pm
« Reply #3 on: June 15, 2007, 08:44:10 pm »
Some one has to say it:   search for "exhaust clamp" here and on www.vwdieselparts.com and you'll find pictures of various home made tools and lots of discussion.
Reply #4June 15, 2007, 10:54:51 pm
foxracer1
  • 991
« Reply #4 on: June 15, 2007, 10:54:51 pm »
take an exhaust clamp and put the nuts on the u bolt. then put the saddle backwards on the ubolt stick in the c clamp and back the nuts off of the u bolt forcing the c clamp apart. a 1.75" or 2" clamp works
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #5June 16, 2007, 07:59:32 am
Darth Garry
  • 136
    • http://www.notinteresting.com
« Reply #5 on: June 16, 2007, 07:59:32 am »
With a pair of these wedges, they become a former-pain-in-the-ass exhaust clamps as with the wedges, it becomes a 2 minute process.
These wedges can be made by anyone with some flat steel stock and a way to cut it and a grinder.
First the photos:
Here are the wedges in action holding the springs open.
Here's the part number of the big one.  I don't know if it's something you can still order, but it is a genuine VW/Audi part.  My dad got a few sets when he worked at the dealership.
So, how do you use these, you ask?
It's simple, and doesen't involve messing around with prybars, weird u bolt openers, or the weird clamp opening tool.  Here's what you need:
EYE PROTECTION!  You are forcing these springs open.  I made the mistake of dropping one once, and there is enough force to send the spring flying.  It flew at me and took a large chunk out of my eyeglasses.  I can't stress this strongly enough!
Your wedges.
A set of channel lock pliers.
2 minutes.
1)  Take the big wedge and jam it into the C clip as far as you can.
2)  Take your channel lock pliers and adjust them to get a good grip on the downpipe.
3)  Rotate the downpipe with the pliers as to force the C clip open further
4)  Jam the wedge in as far as it will go.
5)  Repeat a few times until you have the C clip open pretty far.
6)  Rotate the pipe the opposite direction.  There should be sufficient space to get the C clip off of the exhaust pipe.
Do the same for the other side, and your exhaust is off!
To put them back on, put the wedged C clip in place, and rotate the downpipe as to open up the C clip enough to get the wedge out.  Repeat.  Done.
If the exhaust clips are going to be off for a while, it is best to take the C clips out of the wedges so they don't get stretched out.
I hope this helps, and maybe will save some of you guys some time.  Maybe someone on here could even market the things.
Garry
All for one, and one for Awesomeness!
Reply #6June 16, 2007, 08:43:44 am
BellCityDubber
  • 251
« Reply #6 on: June 16, 2007, 08:43:44 am »
Quote from: "foxracer1"
this is the way I've always done it
Reply #7June 16, 2007, 12:07:49 pm
CoolAirVw
  • 175
« Reply #7 on: June 16, 2007, 12:07:49 pm »
Aqui esta.
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #8June 18, 2007, 02:22:32 pm
saurkraut
  • 904
« Reply #8 on: June 18, 2007, 02:22:32 pm »
Muffler clamps are the best.  2.5"  Especiall on the TDs.  Muffler clamps fit in there better than the purpose built tools.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #9June 18, 2007, 06:13:28 pm
Black Smokin' Diesel
  • 656
« Reply #9 on: June 18, 2007, 06:13:28 pm »
IMO using any tool and any trick in the world, it's still a PITA to do. The exhaust clam trick works good but it's a PITA to work with when removing the passenger side clamp.
