Author Topic: Radiator fan not kicking in!  (Read 5704 times)
June 13, 2007, 10:18:57 am
MontanaGTD
  • 230
    • http://www.dub-style.com
« on: June 13, 2007, 10:18:57 am »
Does the GTd run an in radiator temp sensor which controlls the fan? If so then mine is humped!
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #1June 13, 2007, 10:54:38 am
« Reply #1 on: June 13, 2007, 10:54:38 am »
yep on the radiator.  lower driver's side.  but check to see if the fan actually comes on when you hook it direct to the battery (don't leave it for too long though... as it is the high speed)
Reply #2June 13, 2007, 11:42:44 am
rubadubdub
  • 109
« Reply #2 on: June 13, 2007, 11:42:44 am »
the way i tested mine was to pull the plug off the switch and bridge the plug terminals with some wire, bypassing the switch. Once bridged if it comes on= broken switch, if it doesnt = broken wire somewhere.
1991 Mk2 Golf GTD
Reply #3June 14, 2007, 05:34:50 am
« Reply #3 on: June 14, 2007, 05:34:50 am »
Quote from: "rubadubdub"
or the harness is corroded... which does usually happen!  best bet is to get some of that dielectric grease
Reply #4June 14, 2007, 03:19:22 pm
mtnbob
  • 738
« Reply #4 on: June 14, 2007, 03:19:22 pm »
where is the switch on my 1.6 n/a? the fan hasn't run since i got it, and the fuses are fine. 1986 golf
96 Subaru Outback Wagon
Reply #5June 14, 2007, 04:35:20 pm
« Reply #5 on: June 14, 2007, 04:35:20 pm »
Lower side of the rad, DS I think
Reply #6June 14, 2007, 05:07:12 pm
mtnbob
  • 738
« Reply #6 on: June 14, 2007, 05:07:12 pm »
thanks i'll check it out when it stops raining 8)
Reply #7June 15, 2007, 02:06:08 am
MontanaGTD
  • 230
« Reply #7 on: June 15, 2007, 02:06:08 am »
I guess that would be on my passenger side then seen as im in the uk ;)
MK3 Polo G40 - Sold
Reply #8June 15, 2007, 04:48:46 am
« Reply #8 on: June 15, 2007, 04:48:46 am »
Quote from: "jtanguay"
regardless, it is very simple to find... just look for the wire harness coming from the radiator.
Reply #9June 17, 2007, 01:37:42 pm
aidan
« Reply #9 on: June 17, 2007, 01:37:42 pm »
Montana, I have an old 8v gti rad I think, it drove home 100 miles or so with the temp gauge sat on half way. If I can find it i'll stick the switch in with the alternator
Reply #10June 20, 2007, 06:18:07 am
MontanaGTD
  • 230
« Reply #10 on: June 20, 2007, 06:18:07 am »
thanks! :)
I rigged up a temporary switch on the dash to turn the fan on when i want to - so as the temp starts to come up to the first notch then i just flick the switch and it doesnt go any higher!
MK3 Polo G40 - Sold
