Author Topic: MK3 5 speed swap into MK2  (Read 9564 times)
June 12, 2007, 05:28:46 am
« on: June 12, 2007, 05:28:46 am »
Okay... big dissapointment here.
turns out that mk3 driveshafts flanges are not only larger, but the length of the driveshaft is longer too; approx 3/4 of an inch... uh oh...
and the actual flange sits out about half an inch as well...
has anyone ever changed the flanges to make this work???  i have another tranny sitting there with the 90mm flanges.
aside from that there is just the spedo cable issue, but i'm not concerned with that...
Reply #1June 12, 2007, 06:02:06 am
« Reply #1 on: June 12, 2007, 06:02:06 am »
Are the u-joints the same size? If so, you could put a flange from the Mk3 shaft on the Mk 2 shaft, so it would match the tranny with the 3 end, and the diff with the 2 end.
Reply #2June 12, 2007, 06:16:30 am
« Reply #2 on: June 12, 2007, 06:16:30 am »
Quote from: "jimfoo"
oddly enough the shaft diameter on the driver's side is smaller  :?  :x
but i like your idea...  maybe i'll just have the shaft cut & re-welded & balanced...
but if anyone has done it this way with success, please share!!
oh yea... don't forget that the flanges on the MK3 trans code CHE stick out about 1/2 an inch more too... so maybe just shortening the drive axles will do it.
Reply #3June 12, 2007, 07:19:19 am
« Reply #3 on: June 12, 2007, 07:19:19 am »
There are also u-joints with one size one way, and another the other. I'd go to an auto parts store with someone who has been in the business a long time though, as they will know what you are asking about. If the slip joint has enough travel, I wouldn't worry about 1/2. Hey, arent you guys supposed to be metric up there?  :wink:
Reply #4June 12, 2007, 08:14:24 am
« Reply #4 on: June 12, 2007, 08:14:24 am »
 :oops:
yea metric... so um... 1.5 cm? lol i didn't mic it or anything... i wish i could talk to someone else who has done the conversion, and find out what they did.
longer axles would be bad if i hit a huge pot hole or something right??? wouldn't it put a lot of stress on the shaft & tranny ???
Reply #5June 12, 2007, 10:34:32 am
BlackTieTD
  • 1512
« Reply #5 on: June 12, 2007, 10:34:32 am »
i have a mkII transmission in my mkIII car. it has the 100mm (mkIII) output flanges in the mkII transmission (which originally had 90mm's)which then allow the mkIII axles to be used.
similarily, in your case, (i think) 90mm (mkII) output flanges could be put into your mkIII transmission. and it should all bolt up. i think  :lol:
alternately, you hybrid the 100mm inner CVs and the mkII axles...
Quote from: "jtanguay"
yep
 :lol: we have to straddle both systems so we can still do business with you archaic americans!!
Reply #6June 12, 2007, 11:18:49 am
« Reply #6 on: June 12, 2007, 11:18:49 am »
Quote from: "BlackTieTD"
yep
cool! so did you do the flange swap or someone else?
Reply #7June 12, 2007, 11:21:45 am
BlackTieTD
  • 1512
« Reply #7 on: June 12, 2007, 11:21:45 am »
i believe dr. diesel did on that car. its not a difficult job though. you have a bentley right??  :lol:
Reply #8June 12, 2007, 11:45:27 am
« Reply #8 on: June 12, 2007, 11:45:27 am »
sure do!!!  funny people on here say i just need the 100mm drive axles  :roll:  lol... but i like a good challenge!
anyone in need of 100mm mk3 axles???  :lol:  i was hoping to use them, as i just found out that my driver's side axle has a tear in the boot coming from the tranny side...  :evil:
ill probably stop over at the stealership sometime and grab those caps... i've talked to a transmission guy and he said that it's real easy to take the flange off, but doing so while saving the cap is a bit tough... and in a pinch would put silicone to seal it up.
also, the tranny i'm stealing the flanges from is an N/A (yet to get the code) but if anyone wants to buy it real cheap, it works, but i don't know about grinds etc...
i've been itching to get this transmission in my car for a while now... the ratio's i have now are pretty disgusting
Reply #9June 13, 2007, 08:30:05 am
BlackTieTD
  • 1512
« Reply #9 on: June 13, 2007, 08:30:05 am »
hrm.. i think that there are 100mm mkII axles out there. maybe for GTI or scirocco. they might fit without changing anything else...
Reply #10June 17, 2007, 01:36:08 pm
MikkiJayne
  • 235
« Reply #10 on: June 17, 2007, 01:36:08 pm »
Hi there,
Are you using the Mk3 02A cable trans? If so then the axles / driveshafts from a Corrado G60 should bolt right up.
Don't your 100mm inner CVs fit on your old driveshafts?
Mikki x
Reply #11June 17, 2007, 02:55:30 pm
« Reply #11 on: June 17, 2007, 02:55:30 pm »
Yes there are 100mm mk2 axles
9A
2Y
ACD
AGB
ACL
AON
AUG
as stolen from www.scirocco.org/gears
I might have a set of 100mm ones in my garage come to think of it...
Reply #12June 18, 2007, 10:32:03 am
« Reply #12 on: June 18, 2007, 10:32:03 am »
hmmmm... should i really go with 100mm though??? i'm only looking to get around 100 hp and 160 ft/lbs torque...  90mm's can handle that right???
Reply #13June 18, 2007, 03:58:45 pm
« Reply #13 on: June 18, 2007, 03:58:45 pm »
I'm pretty sure they can handle it, but what's easier, swapping complete axles or flanges?
Reply #14June 18, 2007, 05:53:57 pm
BlackTieTD
  • 1512
« Reply #14 on: June 18, 2007, 05:53:57 pm »
for ease finding direct swap axles would be best. alternately you could fit 100mm CVs to the old axles, i think they will fit as Mikki suggested. you might as well keep the 100s, no harm in it. if you have the 90mm flanges and no other parts, you could put them in that gearbox for time/money savings.
