max break pressure for 1.6 NA injectors?
Topic: max break pressure for 1.6 NA injectors? (Read 2452 times)
June 11, 2007, 04:46:10 am
knowtwodrugs
User+
June 11, 2007, 04:46:10 am »
I have my injectors apart and soaking in diesel, and before I put em back together I was wondering if it was a good idea to up the breaking pressure a little on them? Also is there anything I should do besides just clean them up in fuel? That's all the Haynes says to do. Thanks.
- Ayrer Performance & Machine -
Performance Valve Jobs, Rod Resizing, Crank Grinding & Polishing, Cam Bearings, Block Squaring, Block Boring, Head Milling, Etc...
"Complete Engine Design For The Type Of Racing That You Do!"
609-835-0779
Over 25 Years Experience
June 11, 2007, 02:12:20 pm
June 11, 2007, 02:12:20 pm »
actually if you check the compression ratio thread, someone experimented, i believe if you put the injectors to td specs and set the timing to 1 mm it will increase your fuel economy
June 11, 2007, 10:24:31 pm
gldgti
June 11, 2007, 10:24:31 pm »
there have been some studies into this.
for an IDI engine, depending on compression ratio and swirlchamber design, the optimum breaking pressure is between 1450 and 1700psi.
hope that helps
aydan
'91 Golf Cabrio 1.9TD
June 12, 2007, 03:10:23 am
Mark(The Miser)UK
June 12, 2007, 03:10:23 am »
Quote from: "libbybapa"
You should throw out your Haynes (or sell it on eBay?).
Andrew
Hey I like 'my' Haynes manuals. They are like a diary littered with all my own personal notes and extra leaves... :mrgreen:
Mark-The-Miser-UK
