Author Topic: Im kicking my own ass...  (Read 5796 times)
June 04, 2007, 06:05:56 pm
Kudagra
  • 738
    • www.no-coast.com
« on: June 04, 2007, 06:05:56 pm »
So I almost have my short block all done for the jetta. Everything but rods/pistons. Had the block bored out, installed main studs, cleaned up all the flashing inside and had aux bearings installed. I had the crank,bearings, front and rear seals and the aux shaft installed. I just finished lapping the valves and installing the CRANE springs and new lifters. I was looking for my custom ground cam and decided to check the fit of the 1.9 steel headgasket.
 WTF?....one port doesnt line up..LIKE a MECHANICAL LIFTER block.
DOH!...I had all my machine work done on the wrong block.
SO now I have to get my HYDRAULIC block (the other one) worked over and transfer everything over.
I just assumed that the block in the car(86...1st year of Hydraulic) was the hydraulic block...it wasnt..obviously.
Atleast one guy down at Vee village (local place here) wanted my other block...Ill see if I can trade him my machined block for all the work I need for my other block.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #1June 04, 2007, 07:10:16 pm
« Reply #1 on: June 04, 2007, 07:10:16 pm »
Wow that really sucks man
Reply #2June 04, 2007, 08:19:44 pm
« Reply #2 on: June 04, 2007, 08:19:44 pm »
You know, there was a thread started on "what was your worst screw up". It does suck big time.
Reply #3June 04, 2007, 08:29:22 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #3 on: June 04, 2007, 08:29:22 pm »
Quote from: "jimfoo"
Yea thats a pretty good one.
Atleast I didnt sell my other block like I was going to a few months ago.
It goes with the "Check the fuses first if its an electrical problem" kind of thing. If you have a hydraulic head...make sure you have a Hydraulic  block.
Reply #4June 05, 2007, 05:22:53 am
saurkraut
  • 904
« Reply #4 on: June 05, 2007, 05:22:53 am »
Or,, Its pipe plug time....
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5June 05, 2007, 10:36:15 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #5 on: June 05, 2007, 10:36:15 am »
Well I just talked to the guy at the local VW place. Im going to trade the mechanical block that is done for the machine work on the hydraulic block. Joy.
Now I have to remove all my main studs and bearings. I hope that loctite didnt harden up too much.
Reply #6June 05, 2007, 10:43:53 am
mst
  • 17
« Reply #6 on: June 05, 2007, 10:43:53 am »
If you need some help? :roll:
Reply #7June 06, 2007, 10:01:23 am
Jetta Fan
  • 286
« Reply #7 on: June 06, 2007, 10:01:23 am »
OUCH! That sucks man.
Good thing you hung on to that extra block and at least you have a deal to get the work done on trade.
We're all entitled to screw ups like that.
1997 Jetta 1.9TD AAZ
Reply #8June 07, 2007, 07:27:24 pm
subsonic
  • 1836
« Reply #8 on: June 07, 2007, 07:27:24 pm »
:shock:  :x
I guess it sounded somthing like this when you found out.
http://www.kjm.org/simpsons/sounds/32dohs.wav
Reply #9June 08, 2007, 12:26:40 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #9 on: June 08, 2007, 12:26:40 pm »
Quote from: "subsonic"
:shock:  :x
actually I said "Aww crap" Then I put my tools down right where I was at, turned off the light and went upstairs.
Just dropped the Hydro block off at the shop..along with the machined solid block, crank and manifolds.
While its there Ill probably get my piston tops done and have my bearings coated.
Reply #10June 08, 2007, 03:08:48 pm
subsonic
  • 1836
« Reply #10 on: June 08, 2007, 03:08:48 pm »
What are you doing to the piston tops?
 How are you modding your bearings?
Reply #11June 08, 2007, 03:24:12 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #11 on: June 08, 2007, 03:24:12 pm »
Just get a hightemp coating on the tops of the pistons and they showed me some bearings that a local racer uses in his aircooled vws. Its like a teflon coating. I guess this guy has all his engines done there and the last one ran out of oil for a few laps. When it was torn down it was still spotless.
