Author Topic: 66 aircooled diesel swap?  (Read 8761 times)
June 04, 2007, 03:11:11 pm
SMOKEYDUB
  • 630
« on: June 04, 2007, 03:11:11 pm »
My buddy just blew his engine in his 66 dune buggy and I am wondering if there is and adapter plates made so you can mate a 1.9 AAZ to the old bug transmission. If not were do i get a decent rebuild kit ? can i get performance camshafts? How well do the respond to porting and polishing and dual carbs? any info on some air cooled stuff would be cool.
Thanks...
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1June 04, 2007, 04:57:22 pm
« Reply #1 on: June 04, 2007, 04:57:22 pm »
i think someone makes one, i've seen alot of watercooled engines in the back of air cooled cars.  especially 8vs, and a 1.9 really is no different from any other 8v
Reply #2June 04, 2007, 05:10:35 pm
« Reply #2 on: June 04, 2007, 05:10:35 pm »
I might be thinking of something else but doesn't the engine spin CCW in an aircooled?
Reply #3June 04, 2007, 06:01:44 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #3 on: June 04, 2007, 06:01:44 pm »
Quote from: "burn_your_money"
no. You can bolt in a Ford 2.3 and it doesnt run CCW.
I happed to have that adapter. :D
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #4June 04, 2007, 07:10:56 pm
« Reply #4 on: June 04, 2007, 07:10:56 pm »
Ok cool, thanks for clearing that up.. I wonder what car I'm thinking of
Reply #5June 05, 2007, 07:03:52 am
Ziptar
  • 565
« Reply #5 on: June 05, 2007, 07:03:52 am »
Kennedy Engineering makes a VW water cooled Diesel to VW Aircooled tranny adapter and pressure plate.
I used to have a link to a page where someone had put a 1.9L TD into an air cooled bug, I can't find it now.
This site has some H2O cooled swap info in it's forums though. http://www.germanlook.com
There have been lots of H2O engine swaps done for aircooleds though, have a look at around germanlook.com. Super Beetles seem to lend themselves better to water cooled swaps as the front strut setup leaves more room for cooling.
On a dune buggy you might be squeezed for good cooling room unless he's got a sand rail, then the world is your oyster.
Reply #6June 05, 2007, 09:00:55 am
« Reply #6 on: June 05, 2007, 09:00:55 am »
The Kennedy site lists a large group of engines they have adapters for and then says:
"All these engines rotate the correct direction except some 4 cylinder Honda and Corvair engines"
Tyler I hope you were thinking about a Corvair as opposed to a Honda... ewwwww !!
Reply #7June 05, 2007, 09:18:33 am
Ziptar
  • 565
« Reply #7 on: June 05, 2007, 09:18:33 am »
Here you go....
If this guy could get a Corrado G60 in his bug.....
http://www.germanlook.com/Forums/showthread.php?t=6849
I have to stop looking at germanlook.com, it's making me want an aircooled with Porsche drive train, suspension, brakes, and wheels..
oh wait... a Type I with Porsche suspension, brakes, and wheels and a TDI-M FTW!!!!
 :lol:
Reply #8June 05, 2007, 12:15:29 pm
FineFrank
  • 72
« Reply #8 on: June 05, 2007, 12:15:29 pm »
Quote from: burn_your_money
Doesn't matter. Just change the r&p to the other side of the case, and you're good to go.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants"   -Albert Camus-
Reply #9June 05, 2007, 03:45:56 pm
Turbinepowered
  • 1206
« Reply #9 on: June 05, 2007, 03:45:56 pm »
Probably the Corvair, who's engine does run CCW.
Reply #10June 09, 2007, 09:04:01 am
Ziptar
  • 565
« Reply #10 on: June 09, 2007, 09:04:01 am »
Here you go.... I went through some old links I saved from a couple years back.
Jackpot!!!  More than you'd ever want to know....
Volks-Swap Watercooled VW to Aircooled VW forum
Shoptalk Forums "Conversion Perversions"
Anyone up for a Aluminum Block 1.2 TDI into an air cooled bug swap????  :D
Reply #11June 10, 2007, 03:33:40 pm
Dr. Diesel
  • 1341
« Reply #11 on: June 10, 2007, 03:33:40 pm »
a lysholm converted G60 beetle, no less! yummy!
