Author Topic: A/C bearings floating through the system  (Read 3326 times)
June 01, 2007, 03:31:18 pm
Kudagra
  • 738
    • www.no-coast.com
« on: June 01, 2007, 03:31:18 pm »
So Im cleaning up my underhood area and I decide Im going to convert the ac to r134a anyway. What do you know...I bumped the line and all the r12 leaked out :)
Anyway I pull off the highpressure hose between the condenser and the expansion valve and look inside. It looks like a pile of small beebees. I figure   welp, A/c is shot.
Anyone  ever had this??
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #1June 01, 2007, 09:26:55 pm
« Reply #1 on: June 01, 2007, 09:26:55 pm »
hmmmm so you took the lower pressure hose off and found small round bb type objects in there???
i highly recommend that you go with duracool.  it runs at a lower pressure than r134a and that means less leaky seals and longer life for the compressor.
my high pressure line from the compressor to condensor had some pitting happening on the inside... i had it blown out with nitrogen and since last year around this time it still works :)
i highly doubt that the bb's are from your compressor though...  as they would need to pass through the receiver drier.
