Author Topic: Hyd Lifters Tapping  (Read 6087 times)
June 01, 2007, 10:04:35 am
gratefuljoe
  • 41
Hyd Lifters Tapping
« on: June 01, 2007, 10:04:35 am »
Hey all,
     First things first:  this forum has been invaluable to me.  Thanks to everyone for all the great everything.
     PROBLEM:  Tapping noise coming from motor after startup, persists for several minutes and goes away.
     ASSUMED: To be the hydraulic lifters, as the timing is spot-on.  The local VW mechanic said that the fluid is likely draining away while she's parked.
     SOLUTION:  The mech. said that there is some special fluid to run before my next oil change, and he's seen that help quite often.  However, this doesn't sound like a real fix.
     IDEAS?:  Is this problem potentially disastrous in any way, or shall I run the oil additive and let it persist?
Thanks in Advance,
GratefulJoe
1991 1.6D Golf
Reply #1June 01, 2007, 10:31:30 am
Northern RD
  • 167
Hyd Lifters Tapping
« Reply #1 on: June 01, 2007, 10:31:30 am »
How many km`s on the engine?
If` it`s over 100k, just pop in a new set and 36mm oil pump. It`s a cheap uprade and, with the temps here in Winnipeg run as low as -40C, it  eliminates the noise for another 100k.
Reply #2June 01, 2007, 11:42:02 am
gratefuljoe
  • 41
Hyd Lifters Tapping
« Reply #2 on: June 01, 2007, 11:42:02 am »
Yes, as you're probably aware, it gets RIGHT-FREAKIN-COLD here in e-town as well.
So...install new lifters and swap in a bigger oil pump.
-Where would I find such an oil pump
-Is the lifter install difficult?
Thanks,
GratefulJoe
Reply #3June 01, 2007, 11:42:33 am
gratefuljoe
  • 41
Hyd Lifters Tapping
« Reply #3 on: June 01, 2007, 11:42:33 am »
woops... 340k on the motor.
Reply #4June 01, 2007, 01:33:48 pm
Northern RD
  • 167
Hyd Lifters Tapping
« Reply #4 on: June 01, 2007, 01:33:48 pm »
Quote from: gratefuljoe
Thanks,
GratefulJoe
I have that pump part # on an invoice but I`m at work:get it to you Monday?
Reply #5June 02, 2007, 03:12:14 pm
gratefuljoe
  • 41
Hyd Lifters Tapping
« Reply #5 on: June 02, 2007, 03:12:14 pm »
That would be just great.  Thank you.
Reply #6June 02, 2007, 11:35:53 pm
Hyd Lifters Tapping
« Reply #6 on: June 02, 2007, 11:35:53 pm »
Do a search here for "36mm oil pump" and you should find the exact part #.
I'm in Edmonton as well and couldn't find it locally anywhere near as cheap as from these guys:
http://www.autopartsonlinecanada.com/
Glad to see another Edmontonian in the mix !!
Reply #7June 03, 2007, 04:35:46 am
subsonic
  • 1836
Hyd Lifters Tapping
« Reply #7 on: June 03, 2007, 04:35:46 am »
068115105AN=36mm oil pump
Reply #8June 03, 2007, 07:58:29 am
Ziptar
  • 565
Hyd Lifters Tapping
« Reply #8 on: June 03, 2007, 07:58:29 am »
I have at least one Ticky lifter in my 03, I thought about running some Seafoam through at the next oil change as I've read on the tex that it can cleanup hydraulic lifters. NAPA stocks it.
Might be worth a try.
I just turned 200,000 miles and my Timing belt is due in another 16K, I'll probably just put new lifters in when I do the belt instead, the perfect time to do it.
Reply #9June 03, 2007, 06:54:31 pm
gratefuljoe
  • 41
Hyd Lifters Tapping
« Reply #9 on: June 03, 2007, 06:54:31 pm »
Thanks for all the help guys.  I think I'll just install some new ones when I do my timing belt, which will be very soon.
Vince, do you have any experience in setting timing, and would you be willing to help for a case of beer?
Cheers,
Joey
Reply #10June 03, 2007, 07:18:44 pm
Hyd Lifters Tapping
« Reply #10 on: June 03, 2007, 07:18:44 pm »
Sure.... have dial gauge/locking plate/locking pin/pulley puller will travel.... allergic to beer but good coffee will do just fine !
vwaldon    AT   gmail.com
Did my lifters the last belt change as well... she's quiet as a mouse... well, a mouse with a 4 banger diesel engine.
Reply #11June 03, 2007, 09:34:36 pm
Hyd Lifters Tapping
« Reply #11 on: June 03, 2007, 09:34:36 pm »
mine make noise at idle... i dont care though  :lol:
building a nice m-TDI  8)
