Author Topic: Question regarding IP timing  (Read 1912 times)
June 01, 2007, 08:10:29 am
red64chevelle
  • 67
« on: June 01, 2007, 08:10:29 am »
I have searched, but can't find definitely the correct IP timing. I have a 84 Jetta 1.6TD that I am doing a timing belt, along with everthing else from ball-joints/control arms to motor mounts.
I have read that the timing stock is to be set a 0.75mm.
Being that I am trying to wring every last hp out of the motor, should I set it to 1.0mm? Or is there a better setting to use?
Thanks in advance.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
1964 Malibu Convertible
Reply #1June 01, 2007, 09:14:29 am
« Reply #1 on: June 01, 2007, 09:14:29 am »
definitely go 1.00mm at least... some say to even go to 1.05mm
