Author Topic: N/A IDI: hard fuel line to injector connection  (Read 1993 times)
May 31, 2007, 11:25:26 am
EvanR
  • 2
« on: May 31, 2007, 11:25:26 am »
Hi gang!
The motor is a 2.4 I-6. Volkswagen built, Volvo chassis.
No matter, really, this question should apply to any IDI VW-built Diesel.
I have a leak where the hard fuel line meets the injector. I've re-torqued the 17mm nut to the point where I don't want to turn it any more.
Still, it leaks. Is there supposed to be a seal there? If not, Is this the sign of a bad line, a bad injector, or something else entirely?
Thanks,
Evan
Reply #1May 31, 2007, 11:30:36 am
bert
  • 423
« Reply #1 on: May 31, 2007, 11:30:36 am »
Undo the both ends,wiggle the pipe a bit and retighten the pipe, usually it reseats the flared end of the pipe into the injector,if not its a new hard line
Bert
Reply #2May 31, 2007, 07:08:19 pm
tylernt
  • 344
« Reply #2 on: May 31, 2007, 07:08:19 pm »
Yes, the hard line unions can become flattened if overtightened, and stop sealing. Maybe if you had some kind of flaring/crimping tool you could restore it?
