Author Topic: 4 speed Rabbit only 45-50mph?  (Read 2902 times)
May 30, 2007, 07:24:02 pm
vegfuel
  • 125
« on: May 30, 2007, 07:24:02 pm »
Hey people
I've got a 1981 VW Rabbit with just the common 1.6 non-turbo. The trouble is the speed. The speedometer looks like it is made for a 5spd. When I go down the road, I stick it in third and it only likes about 30mph, at 35 it's starting to scream. After that I must shift to 4th and it likes 45mph and is screaming at 50!! My speedometer shows all the way to 85. Should a 4spd be able to handle 60? Is something wrong with pump timing? I was hoping on using this for long trips at 55-60mph.
1986 Golf WVO converted.
Reply #1May 30, 2007, 08:58:41 pm
CoolAirVw
  • 175
« Reply #1 on: May 30, 2007, 08:58:41 pm »
So....  are you saying your speedo is inaccurate or your motor has no power?
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #2May 30, 2007, 09:26:17 pm
vegfuel
  • 125
« Reply #2 on: May 30, 2007, 09:26:17 pm »
hey there,
To be frank I don't know if I have 5spd or a 4spd. I just know that I should be able to top out at 60mph in 4th if it's a 4spd. If it is a 5spd, where is 5th gear? I tried to find it by going throught he gears and then pressing in on the shifter (like you would in reverse) and locking it in what I thought was 5th. All I know is is that it's at high rpm at 45mph, isn't that a bit bad for a 4spd Rabbit diesel?
Reply #3May 30, 2007, 10:36:05 pm
lyeinyoureye
  • 96
« Reply #3 on: May 30, 2007, 10:36:05 pm »
Maybe it's a combo of your speedo being off, and having a relatively high GC trans. Is there anyone who can drive w/ you and verify your speed?
Reply #4May 30, 2007, 11:18:43 pm
rabbid79
  • 684
« Reply #4 on: May 30, 2007, 11:18:43 pm »
Check the code stamped on a little flat area under the transmission on the bell-housing, and then search around on the internet for what it means.  Techtonics tuning has some good info on tranny codes.  It's possible that it's a 5-speed, but the linkage is screwed up and won't let you get into 5th.
I have a '79 with the 1.5 and a 4-speed.  I can do almost 85 in it.
'15 WRX
Reply #5May 31, 2007, 05:31:37 am
yankeejim
  • 8
« Reply #5 on: May 31, 2007, 05:31:37 am »
Once you get the tranny code from the bottom of the bellhousing, this should tell you whether it is a 4- or 5-speed.  It will also give you an idea of expected RPM at speed.
http://www.scirocco.org/gears/
'92 Jetta ECOdiesel
