Author Topic: Quick question, search is pretty lame...  (Read 2717 times)
May 26, 2007, 10:28:17 am
Black Smokin' Diesel
  • 656
« on: May 26, 2007, 10:28:17 am »
Can you swap the TD pump top onto a NA pump? Will is provide the same fueling?
Reply #1May 26, 2007, 11:13:52 am
subsonic
  • 1836
« Reply #1 on: May 26, 2007, 11:13:52 am »
Well if you have a Eco diesel, you can swap out the top and make it a "real" TD pump.  I would expect that if you are in the rebuild phase of a pump you could swap out / in the appropriate parts.  Don't know for sure though.
Reply #2May 26, 2007, 01:11:15 pm
  • 656
« Reply #2 on: May 26, 2007, 01:11:15 pm »
Quote from: "libbybapa"
The ECO pump was actually an 8mm plunger and so simply swapping the top will not make it a TD pump which came with a 9mm plunger.  A TD pump onto a n/a pump should work.  I haven't run one that way yet, but have heard of others doing it and can't see any reason it wouldn't work.
Andrew
8mm? wow... So the NA pump is a 9mm? Or should be, the numbers on the pump should tell me what size it is.
Reply #3May 26, 2007, 02:06:00 pm
« Reply #3 on: May 26, 2007, 02:06:00 pm »
yeah the na pumps are actually better than the eco pumps... seems like most people don't know that though
Reply #4May 26, 2007, 03:01:58 pm
  • 656
« Reply #4 on: May 26, 2007, 03:01:58 pm »
Quote from: "Trev0rbr"
Well now I know :lol:
