Author Topic: Blow apart diagram of aneroid pin asembly  (Read 3639 times)
May 25, 2007, 11:20:54 pm
Cheesetoast
  • 285
« on: May 25, 2007, 11:20:54 pm »
i'd like as many pictures of this as i can, i want to make absolutely sure it's back in there right.  is it ok to use the small shorter spring? advantages?  i need to know what if any washers go where, the one i replaced mine with was slightly different.
Reply #1May 25, 2007, 11:30:35 pm
Cheesetoast
  • 285
« Reply #1 on: May 25, 2007, 11:30:35 pm »
the 1.9 pin that was in there had this metal washer, the 1.6 one didn't, i used the shorter spring and this washer. good?
Reply #2May 25, 2007, 11:52:24 pm
Cheesetoast
  • 285
« Reply #2 on: May 25, 2007, 11:52:24 pm »
do i need this o-ring/gasket?
Reply #3May 26, 2007, 12:20:59 am
zagarus
  • 619
« Reply #3 on: May 26, 2007, 12:20:59 am »
u need to use the macro feature on your camera lol :lol:
but i hear you can use the 1.6 pin in place of the 1.9
Reply #4May 26, 2007, 01:31:12 am
Cheesetoast
  • 285
« Reply #4 on: May 26, 2007, 01:31:12 am »
that is hte macro feature..... really old canon a40
Reply #5May 26, 2007, 01:50:59 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #5 on: May 26, 2007, 01:50:59 am »
look at your pin and you will know if you need washer
canon a40 can make good makro
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #6May 26, 2007, 05:44:51 am
« Reply #6 on: May 26, 2007, 05:44:51 am »
Quote from: Cheesetoast
Dude! That's my pin. It was slready like that when I bought it.  So if other diesels have VE pumps, are there other pumps that have pins like the 1.6, that will fit our pumps?
Reply #7May 26, 2007, 09:12:15 am
Cheesetoast
  • 285
« Reply #7 on: May 26, 2007, 09:12:15 am »
Quote from: "zaprzal"
um, huh? so if it's the 1.6 pin like that i should use the washer?
