HELP!!! odd noise comming from front passenger side
Topic: HELP!!! odd noise comming from front passenger side (Read 5009 times)
January 05, 2005, 12:41:42 am
Topherdiesel
January 05, 2005, 12:41:42 am »
When driving along, when I turn the wheel even a little to the left, i hear a wierd noise comming out what seems to be the passenger side wheel area...
I have checked the wheel bearings on both sides
what the hell could it be?
maybe the brakes dragging???
I could swear that sometimes I feel it in my brakes??
Would brakes do that?
I may rebuild them tomorrow just for the hell of it?
But I would rather not if thats not it!
HELP!!!
Back to top
Wait, can the wheelbearing be worn without actually having side to side movement as we are used to seeing in really bad cases?
January 05, 2005, 03:04:04 am
mk1vdub
January 05, 2005, 03:04:04 am »
if you have power steering it could be the pump making noise?
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
January 05, 2005, 06:37:41 am
Topherdiesel
January 05, 2005, 06:37:41 am »
Nah, its more of a grinding, definately not an accessory or pulley!
January 05, 2005, 07:39:00 am
Mikeyworks
January 05, 2005, 07:39:00 am »
Sounds like a CV joint going south to me. Time to get yourself a new driveshaft (probably easier than trying to replace just the CV joint.
Mikey
January 05, 2005, 09:30:25 am
Topherdiesel
January 05, 2005, 09:30:25 am »
Even if I just turn the wheel just a touch
like
not enough to even change lanes
just enough to turn the wheel a bit
put some sideways pressure on it
January 05, 2005, 10:25:21 am
QuickTD
January 05, 2005, 10:25:21 am »
I'm voting for a front wheel bearing. The race gets a few pits in it and makes a helluva noise. This will go on for a few thousand km before you will detect any noticable play.
I had an outer CV joint go south on my A3. It was more of a rythmic knocking, once per revolution of the wheel. Wheel bearings make a low growl that increases in frequency with wheel speed and gets louder when the "bad" wheel is under load. Wheel bearing noise kinda sneaks up on you over time, you don't really notice how loud it has become. After you get it fixed you won't believe how quiet the car is.
January 05, 2005, 11:08:50 am
Topherdiesel
January 05, 2005, 11:08:50 am »
Yeah
i am detecting some play in it now, off to frisco I go for some parts!
January 05, 2005, 12:09:39 pm
SMOKEYDUB
January 05, 2005, 12:09:39 pm »
To check wheel bearing play you grab the wheel (top and bottom) and move it up and down. Side to side is for tie rods. Wheel bearings usually make a howling noise when you put a load on them when your driving i.e. turning the wheel a little bit. By turning the steering wheel left a little bit it puts load on the right wheel bearing so that is probably your answer right there. Wheel bearings are cheap at 33 Dollars.
Good luck
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
January 05, 2005, 10:56:36 pm
Topherdiesel
January 05, 2005, 10:56:36 pm »
It wass 30 bux, italian made, so I have to lube it with tomato sauce before I slap it in!
ps
I've got a little bit of italian in me, so its ok for me to say things like that!
:p
January 06, 2005, 12:49:19 am
January 06, 2005, 12:49:19 am »
yea i had to replace a wheel bearing on my golf. The slightest turn made it have this vibrating noise (turning left only, right side bearing) Once you know the sound... you won't forget it (or the price to fix it hehe)
May 14, 2005, 10:37:19 pm
srivett
May 14, 2005, 10:37:19 pm »
Now that I've replaced my AWY with an AGS I can hear a wheel bearing going bad at highways speeds. Anywbody know what the wheel bearing kits include? They are double the price of the bearings so surely they must include more than a couple circlips. :?:
Thanks, Steve
1992 1.6D Golf - 412K km
Mint except for chipped paint, no rust
Reply #11
May 15, 2005, 11:40:46 am
fspGTD
Reply #11 on:
May 15, 2005, 11:40:46 am »
Or maybe try some virgin olive oil. :lol:
- Jake (not Italian, but have visited Italy!)
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
