Author Topic: exhaust  (Read 2081 times)
May 21, 2007, 08:23:14 pm
rabbit GTI/GTD
  • 58
exhaust
« on: May 21, 2007, 08:23:14 pm »
Maybe a dumb question, but. will an high perf. cat back exhaust made for an MK3 golf gasser work on my diesel(even if i have to join it somwhere with clamps instead of the cat) cause i may be able to get one real cheap, along with some Halo headlights(with turn signals in the headlights)
Reply #1May 21, 2007, 08:26:56 pm
Black Smokin' Diesel
  • 656
exhaust
« Reply #1 on: May 21, 2007, 08:26:56 pm »
what generation is your diesel? It will work on a MK2 but the hangers aren't located at the same place. It will also work on a MK3, no problem there.
Reply #2May 21, 2007, 08:40:33 pm
rabbit GTI/GTD
  • 58
exhaust
« Reply #2 on: May 21, 2007, 08:40:33 pm »
sorry, i thought i put what my car is, its an mk3 golf as well, with a 1.6  TD( i know, my 1.9 dropped a valve, i had it kicking around) i just put new cam followers a timing belt, livened it up a lot, so i have a lead on this exhaust, just wanted to make sure it was a direct fit(with small modifications) thanks for the reply. what can u use for a cheap Boost controller(homemade kinda deal)?? i was thinking air regulator for compressed air?? anyone use with any success?
Reply #3May 21, 2007, 08:47:36 pm
  • 656
exhaust
« Reply #3 on: May 21, 2007, 08:47:36 pm »
Quote from: "rabbit GTI/GTD"
Air regulator should work, and I've heard a plumbing/pool pressure gauge can be used as a boost gauge :D
