Author Topic: TDI(crank damage, bent valves?)  (Read 3421 times)
May 20, 2007, 05:06:58 pm
rabbit GTI/GTD
  • 58
« on: May 20, 2007, 05:06:58 pm »
have a lead on a TDI, not to sure the year yet, i'm thinking a 99. the crankshaft gear bolt and crank is worn from what i was told and wont run, so, i'm nor familiar with tdi's, only idi's (as per why i'm posting here) , are the TDI's  interference engine to??, will the valves be bent like my 1.9 aaz did, lol. Even if the engine is done, the VNT turbo should be good for my 1.6, if i get the car. Thanks for now guys
Reply #1May 20, 2007, 07:03:11 pm
« Reply #1 on: May 20, 2007, 07:03:11 pm »
I think almost every diesel ever made is an interference engine, except for Ford transit vans. Good luck.
Reply #2May 21, 2007, 08:11:05 am
rabbit GTI/GTD
  • 58
« Reply #2 on: May 21, 2007, 08:11:05 am »
thanks, my thought was that it may not hit the valves since the pistons are slightly dished in a tdi,
Reply #3May 21, 2007, 12:02:22 pm
andysimpson
« Reply #3 on: May 21, 2007, 12:02:22 pm »
Quote from: jimfoo
I think every diesel ever made is an interference engine. Good luck.
Old ford transits never bend valves.
Reply #4May 21, 2007, 04:04:07 pm
DVST8R
  • 535
« Reply #4 on: May 21, 2007, 04:04:07 pm »
vw diesels almost always do.  :wink:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #5May 22, 2007, 02:07:35 pm
Baxter
« Reply #5 on: May 22, 2007, 02:07:35 pm »
Quote from: andysimpson
Quote from: jimfoo
Eeehh, that tek's mi bak!
I used to work on Transits, right laugh.
I did a few heads on them, they always seemed to stick to the block, remember one we had the engine crane on the head and the front wheels off the floor! the head only came loose when we jumped on the bumper!
 :lol:
Them flipping timing cover things that used to wear aswell, heh, memories.
I like doing timing belts on the 2.5 DI, just a few drill bits for the timing pins, brilliant, just *** slow!
