Author Topic: wtb: 1.6td crank and rods  (Read 6155 times)
May 20, 2007, 12:13:39 pm
k5ryannc
  • 18
« on: May 20, 2007, 12:13:39 pm »
i had a connecting rod bearing go and got bad quick witch took out the crank, rods and, some pistons . the block is in great shape but if the price is right on a short block assembly i'd probably be interested
also if anyone knows where i can get the p100 rods in the US i'd be thankful for any information
thanks
 ryan
81 caddy 1.8 fi 5sp 34-36mpg and resonably fast (dd)
86 jetta gl 1.6 idi td fixing a scam project (i got had)
88 tube sami with 1.6 idi td, toy trans +tbox+upsidedown, dana 300, 3/4ton axles 37's (work in progress)
Reply #1May 20, 2007, 07:54:11 pm
blkboostedtruck
  • 1535
« Reply #1 on: May 20, 2007, 07:54:11 pm »
i think your ok! you can use 1.6 n/a rods and crank they are the same as TD the difference was in the pistons were made stronger and cut outs for the under piston oil squirters and better materials used in the head to handle the heat and extra air induction thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2May 21, 2007, 02:08:48 pm
k5ryannc
  • 18
« Reply #2 on: May 21, 2007, 02:08:48 pm »
thanks so much for the info!!!!!!!!!!!!!!!!
I GOT THE PISTONS AND RODS COVERED
now i just need a crank
thanks again guys i love this board
ryan
Reply #3May 21, 2007, 02:12:59 pm
« Reply #3 on: May 21, 2007, 02:12:59 pm »
Just throwing that out there... now VW probably started using the same TD crankshaft for both TD and N/A, but I am not sure of when... possibly the same time they introduced the Hydraulic lifter head???
Reply #4May 21, 2007, 06:11:45 pm
k5ryannc
  • 18
« Reply #4 on: May 21, 2007, 06:11:45 pm »
thanks again for the info jtanguay
alot of guys at my shop keep telling me have the crank welded up and turned back down to spec
i have a gut feeling this is not really the correct way to do it
any opinions????
thanks
ryan
Reply #5May 21, 2007, 08:00:07 pm
Black Smokin' Diesel
  • 656
« Reply #5 on: May 21, 2007, 08:00:07 pm »
Quote from: "k5ryannc"
any opinions????
thanks
ryan
IMO it's not a very good idea. It may be ok for a gasser but I wouldn't try on a diesel. Cranks can be found for cheap anyway.
Reply #6May 21, 2007, 08:00:21 pm
blkboostedtruck
  • 1535
« Reply #6 on: May 21, 2007, 08:00:21 pm »
the crank can be repaired but it has to be done properly ! the crank in my gas turbo truck has been welded on to make it a stroker crank it's now a 1.9 liter it's been reground and polished and balanced and knife cut ! that was done in '85 and it's held up all this time ! i have ran it hard out at the drag strip a few times and never thought twice about it ! so i say go for the repair!!
 and also did anyone know that TD injection lines have a larger I.D and longer in length then N/A diesel injector lines?   Duane
'66 variant 1500S
Reply #7May 21, 2007, 08:29:45 pm
« Reply #7 on: May 21, 2007, 08:29:45 pm »
Repairing a crank is perfectly fine
Reply #8May 21, 2007, 11:51:10 pm
  • 2932
« Reply #8 on: May 21, 2007, 11:51:10 pm »
I hear the crank from a 1.8 16V is the same thing.
 Maybe you can find one of those locally.
Reply #9May 22, 2007, 01:59:44 pm
« Reply #9 on: May 22, 2007, 01:59:44 pm »
yea there should be no problem with getting it done properly.
hmmmm vw is smart if they used their TD crank with a 16V gasser.  saves on fabricating two different types of cranks for two different engines.... much cheaper in the long run with less over-produced parts that will never sell.  plus the TD cranks are very strong!
