Author Topic: WTB mk2 diesel insterment cluster w/ tach  (Read 4667 times)
May 20, 2007, 12:08:23 pm
blkboostedtruck
  • 1535
« on: May 20, 2007, 12:08:23 pm »
i'm looking for a tach from a mk2 diesel that i can use in my TD pickup i need the one that runs off of the W terminal from the alternator i have mk1 gas cluster with tachs if someone would like to trade me or trade for something else ? or just sell to me ! doese'nt matter if it's in KM or MPH
  thanks Duane
 P.S. i have caddy parts if anyone needs something  let me know?
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #1May 21, 2007, 05:52:39 pm
« Reply #1 on: May 21, 2007, 05:52:39 pm »
CE1 or CE2?
Reply #2May 21, 2007, 08:35:23 pm
blkboostedtruck
  • 1535
« Reply #2 on: May 21, 2007, 08:35:23 pm »
I guess it don't matter as long as came out of a factory diesel that the tach ran off of the W terminal of the alternator! i got 3 or 4 gas clusters but i don't want to go through modifications to make the gas tach cluster work i'm not into changing diodes and soldering too tedius for me! i'm going to use a jetta mk1 dash in my '81 TD pickup . so was that a CE2 that VW used in german spec models? Thanks Duane
'66 variant 1500S
Reply #3May 22, 2007, 05:53:15 pm
Mk2Fanatic
  • 93
« Reply #3 on: May 22, 2007, 05:53:15 pm »
Quote from: blkboostedtruck
CE2 is 90(89.5 if german I believe) til the end of mk3 production.(B3/b4 Passat as well)
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #4May 22, 2007, 06:12:53 pm
blkboostedtruck
  • 1535
« Reply #4 on: May 22, 2007, 06:12:53 pm »
ok then i need one from an A2 chassie 85 to89 diesel !it should say diesel right on the tach . i'm putting it in a 81 pickup with a jetta dash .
 Duane
'66 variant 1500S
Reply #5May 22, 2007, 06:59:50 pm
Mk2Fanatic
  • 93
« Reply #5 on: May 22, 2007, 06:59:50 pm »
I'm going to the local VDub wreckers this weekend, I can see if there are any diesel tach clusters on cars while I'm there...
Reply #6May 23, 2007, 12:16:44 am
blkboostedtruck
  • 1535
« Reply #6 on: May 23, 2007, 12:16:44 am »
hey thanks, that would be awsome ! hope its under 75 us dollars and if ther is any thing i can locate for you here in the usa let me know? thanks Duane
'66 variant 1500S
