Author Topic: 1Y Frankenstein  (Read 2640 times)
May 20, 2007, 01:27:41 am
Ghia
  • 17
1Y Frankenstein
« on: May 20, 2007, 01:27:41 am »
Ok the GTD engine bits didn't really work out as planned so...
I'm going to look at a car later on which I think has a 1Y (1.9 N/A) motor in it.
Having just read the first 20 pages on this forum ( :shock: ) I have picked up the following info.
1.6 GTD cam has slightly better lift than the 1.9.
Both the 1Y and AAZ have piston squirters.
Are the compression ratios different between 1Y and AAZ?
Merc NA34X injectors will work better than GTD (SB code) injectors if I can find some (but we have had a 300 TD Merc in the family for over 10 years  :twisted: )
GTD pump should work on the 1Y without probs (please let me know if this isn't right!)
I checked that the exhaust valves on the AAZ and 1Y are the same although the inlets have a different part number  :?
The nice inlet manifold which Baxter pointed out comes on the 1Y so that will help.
Oh and a Chargecooler wouldn't go amiss...
This would be going into a T3 Bluestar so the exhaust system is already about 2.5inch bore from VW.
MG
Reply #1May 20, 2007, 02:31:31 pm
andysimpson
1Y Frankenstein
« Reply #1 on: May 20, 2007, 02:31:31 pm »
Same compression ratio.
Different pistons and pins (2mm smaller)
Different con rods and big end bearings.
Reply #2May 20, 2007, 02:39:27 pm
Black Smokin' Diesel
  • 656
1Y Frankenstein
« Reply #2 on: May 20, 2007, 02:39:27 pm »
This has nothing to do with your engine build but wouldn't you happen to have any high resolution pictures of your T3. It looks really good!
Reply #3May 20, 2007, 02:47:56 pm
Ghia
  • 17
1Y Frankenstein
« Reply #3 on: May 20, 2007, 02:47:56 pm »
Er thanks..   :)
I run it on the multispoke wheels but had 996 Turbo wheels on it for an hour and took some bigger pics of it then.
I need to have a few paint bits done here and there but am slowly improving it.
MG
Reply #4May 22, 2007, 02:15:30 pm
Baxter
1Y Frankenstein
« Reply #4 on: May 22, 2007, 02:15:30 pm »
From what I can gather the ABL (T4 1.9TD) is very similar to the AAZ but without a LDA on the pump, need to check a few bits but it opens up the search for AAZ'a s they seem to command an unrealistic scene tax, specially taking into account the issues the crank and pulley have.
