Author Topic: pump tool  (Read 3769 times)
December 29, 2004, 07:26:29 pm
panzerx
  • 10
pump tool
« on: December 29, 2004, 07:26:29 pm »
does anyone know where i can get the appropriate tool to loosen the triangle shaped bolts that the governor assembly rotates on? or even what it might be called?
Reply #1December 29, 2004, 08:03:19 pm
Dr. Diesel
  • 1341
pump tool
« Reply #1 on: December 29, 2004, 08:03:19 pm »
you could probably make it out of steel rod with a drill and some creative filing.
Reply #2December 29, 2004, 09:16:12 pm
MacGyver
  • 245
pump tool
« Reply #2 on: December 29, 2004, 09:16:12 pm »
QuickTD could make & sell you one, but since you're in the US check this out:
http://shop.metalnerd.com/index.cgi?code=3&cat=5
Last item on page.
Reply #3December 29, 2004, 09:34:57 pm
QuickTD
  • 1156
pump tool
« Reply #3 on: December 29, 2004, 09:34:57 pm »
Macgyver, that metalnerd tool is for the little (8mm across flats) top pump cover bolt on the TDI. I've made those but I'm pretty sure panzerx is looking for the larger triangular socket to fit the large 12mm governor pivot bolts on the non-EDC VE pumps. I've made those as well.
Panzerx, shipping to the US would likely outspend the tool but PM me if you're interested...
Reply #4December 29, 2004, 09:36:29 pm
panzerx
  • 10
pump tool
« Reply #4 on: December 29, 2004, 09:36:29 pm »
that's the right head, but the size of it is way too small, i already have one
Reply #5December 30, 2004, 08:12:54 am
MacGyver
  • 245
pump tool
« Reply #5 on: December 30, 2004, 08:12:54 am »
Oops sorry I didn't realize there were two different sizes! :oops:
I know some guys on the TDI Club have jammed a similar sized regular socket over the smaller top one to get it out, could you do the same with the larger one? A really cheap crappy offshore socket should have enough give in it to be forced on, like one from those 40pc $5 sets?
