Author Topic: SB Code engine bits (UK)  (Read 3597 times)
May 15, 2007, 02:48:10 pm
Ghia
  • 17
« on: May 15, 2007, 02:48:10 pm »
Have just stripped down a seized SB code engine. (Rod bearing failure)
I'm using the head/cam/injectors and pump but the rest will be for sale.
Good turbo with all oil/water pipes etc. Block is a bit of a mess as is crank and one rod. Turbo sump available, also alternator bracket, power steering bracket etc.
If you need anthing give me a buzz, it won't be expensive!
Parts in Leeds, UK.
07989 333437
