Are any VNT turbos direct bolt-on 1.6TD?
Topic: Are any VNT turbos direct bolt-on 1.6TD? (Read 2954 times)
May 14, 2007, 02:37:58 pm
rallydiesel
May 14, 2007, 02:37:58 pm »
Any VNT turbos out there that are direct bolt on to the 1.6 TD? If not, what kind of manifold mods must be done? I am aware of the problems with the VNT actuator adaptation but I would be willing to go fairly high boost (hopefully less than 20 PSI :oops: ) and just switch the wastegate actuator with the VNT actuator along with some messing around.
So are there any fairly simple VNT options. I am thinking about a VNT 15 but just need to know if there would be any fabricating involved :roll:
1991 Jetta TD - sold
2001 Golf TDI - Son's
May 14, 2007, 06:35:19 pm
May 14, 2007, 06:35:19 pm »
the guy i know that did it all you really have to fab is the down pipe. and i guess some kind of an intake. the turbo/manifold itself bolts right on.
May 15, 2007, 12:04:39 pm
rallydiesel
May 15, 2007, 12:04:39 pm »
So only the euro VNT turbos are separate from the intake manifold?
May 15, 2007, 07:17:31 pm
May 15, 2007, 07:17:31 pm »
The intake manifold is part of the turbo? I thought it was just the exhaust manifold...
May 15, 2007, 07:21:53 pm
May 15, 2007, 07:21:53 pm »
yeah just the exhaust
May 15, 2007, 07:25:27 pm
May 15, 2007, 07:25:27 pm »
Thanks
