Author Topic: Need help with parts location and prices  (Read 3059 times)
May 11, 2007, 11:07:42 am
subsonic
  • 1836
« on: May 11, 2007, 11:07:42 am »
Hey guys,
 I need to get some parts for my build.  I am sure others could benifit from this as well.  Yes I did the search, but came up with only limited results, and I need to jet so I figured I would post a Quick question.
Perhaps when this gets answered we can move it to the FAQ section.
Windage tray for the 1.6.
Cam shaft oil baffle. (1.9 and 1.6)
Crank scraper.
Is there a generic part number for these?
I am looking for links or leads for them.  If you know prices even better. What other applications will transfer over to the 1.6 and fit for these?
Gotta fly,  Jim
Reply #1May 11, 2007, 11:11:16 am
boosted_diesel_84
  • 216
« Reply #1 on: May 11, 2007, 11:11:16 am »
the cam oil baffle can be found in a junk yard, ive seen many there on older gas V dub's
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #2May 11, 2007, 03:39:42 pm
BruceM31
  • 64
« Reply #2 on: May 11, 2007, 03:39:42 pm »
the oil pan baffle can be bought at any worldpac supplier.  Carquest Auto parts is tied into their system, the part number from wordpac is A6134-51545-OEA. If you give this number to any carquest store they can get it for you! and if they won't contact me I am the associate manager of a large carquest in wisconsin and WILL get it for you
Thats not a rod knockin..........its a diesel!
Reply #3May 11, 2007, 04:28:01 pm
« Reply #3 on: May 11, 2007, 04:28:01 pm »
the cam splash thing is on all the newer 2.0's too well the mk3 t.0's atleast, i'm not sure about the mk4 ones.... they're easy to comby though
Reply #4May 11, 2007, 08:58:53 pm
« Reply #4 on: May 11, 2007, 08:58:53 pm »
BFI also sells the windage tray
www.blackforestindustries.com
Reply #5May 16, 2007, 10:10:57 pm
rabbit_diesel
  • 44
    • http://www.vwvortex.com
« Reply #5 on: May 16, 2007, 10:10:57 pm »
You should try www.autohausaz.com they have a good selection of vw parts :wink:
i'm dubbin it
