Author Topic: Help ASAP w/ fluid leak....please  (Read 7679 times)
May 06, 2007, 02:33:02 pm
TD_Bunny
« on: May 06, 2007, 02:33:02 pm »
I have almost reached my financial limit with my car but i need some input on my newest problem. I started my car this morning, drove it about 150ft, got out to go inside my house, and noticed fluid coming down from my engine compartment. I checked my coolant resevoir and the fluid did not change level, the fluid is not black or dark whatsoever, my car doesnt have power steering, and is coming from the IP, front side of the engine. I think the fluid is fuel but i am not 100% sure yet. The fluid has an oil/fuel odor. What the heck could it possibly be? Are there gaskets or seals that can go bad in this area? What on the IP or fuel line could be leaking? I hope i can detect where it is leaking without pulling the IP out or does not cost me a lot of money to replace. I am already having to replace the clutch....but that is a another story.
While this may be a seperate issue, i also have oil dripping from above my oil pan near the water pump???? This leak is coming off of the lowest pulley housing and i have not determined where it is coming from.
I will have a chance to take a closer look in a couple of days but if anyone has had a similiar problem or extra insight before i dig in i would appreciate it. thanks
Reply #1May 06, 2007, 05:48:00 pm
« Reply #1 on: May 06, 2007, 05:48:00 pm »
yep... you have a leaking injection pump!  you can usually get it sealed for around $250 at a shop (seals only.. no calibrations or anything else)
Reply #2May 06, 2007, 06:37:53 pm
rallydiesel
  • 1880
« Reply #2 on: May 06, 2007, 06:37:53 pm »
If you are good mechanically you can rebuild the pump using this kit:
http://www.emiata.com/DieselVW/BoschRebuildKit.htm
I have no idea what is involved in replacing all the seals, but having done the governor mod, I can say the pump is a very complicated piece of machinery that you do not want to screw up.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3May 06, 2007, 08:28:19 pm
Re: Help ASAP w/ fluid leak....please
« Reply #3 on: May 06, 2007, 08:28:19 pm »
Quote from: "TD_Bunny"
cam, IM or crank shaft seal from the sounds of it...
Reply #4May 06, 2007, 08:34:20 pm
935racer
« Reply #4 on: May 06, 2007, 08:34:20 pm »
Definitely sounds like a leaky injection pump, if you are near the financial limit of your car and not very mechanically inclined now would be the time to off load it, its fairly difficult to re seal a pump (and actually replace all the seals) and its also very easy to ruin the pump in the process, while you have it out might as well the do the timing belt as well.
Reply #5May 07, 2007, 10:36:19 am
TD_Bunny
« Reply #5 on: May 07, 2007, 10:36:19 am »
Well...crap.
There is only one ADS certified diesel shop where i live and the quote is around 650-850 dollars. And they said it could be more if more problem arise. Yeah dont think i can do that  :(
Anyone want a rabbit? lol no i dont know yet but at least the engine is in great shape, other than the possible cam seal leak. Clutch and cam leak fixed, great running engine with low miles, how much can i even sell the car for without a IP? any suggestions?
Still might try to fix it but that is a crap load of money. They said they have gotten a lot more rebuilds due to the fuel and they confirmed this with Bosch. Sux to be me.
BTW, does anyone know if the 825 USD for a Giles pump includes calibration or would i still have to get the pump calibrated?
Reply #6May 07, 2007, 10:45:46 am
« Reply #6 on: May 07, 2007, 10:45:46 am »
with the engine running, see if one of the injector pipes is leaking, or the injector return loops....
Reply #7May 07, 2007, 11:21:40 am
TD_Bunny
« Reply #7 on: May 07, 2007, 11:21:40 am »
Yeah i am going to check much closer when i get home from work today. Just the day before i filled up and got 45mpg and had no apparent leaking issues. Start up the next day and have fluid coming down.
Reply #8May 07, 2007, 05:41:20 pm
tylernt
  • 344
« Reply #8 on: May 07, 2007, 05:41:20 pm »
Where do you live?
I saw a VW Quantum with a pump leak on Craigslist for $500. I was tempted to buy it.
Yup. Many, many people got bit by this. So far I've been ok, but I use Power Service fuel additive every fillup. It might help, it might not.
As far as I know, Giles does indeed calibrate it. You will still need to time it after getting it back in the car, though.
Reply #9May 07, 2007, 05:48:45 pm
« Reply #9 on: May 07, 2007, 05:48:45 pm »
If you search the threads here and the forums at www.vwdieselparts.com you should find at least one pointer to a guy on eBay who does resealing for a couple hundred... no one has complained about his work thus far so it might be an option to buy you a little time.
You can also get ahold of Giles and find out what he charges to do a simple reseal... no mods, no firebreathing... another possibility.
Reply #10May 07, 2007, 06:22:19 pm
TD_Bunny
« Reply #10 on: May 07, 2007, 06:22:19 pm »
Just got home and fired her up. No leaking at all????? Is there an overflow valve or something? The leak was not just a little drip either, but when i got a mechanic to look at it, and drive it, it never leaked. Guess i will just have to see over time if it does it again.
Reply #11May 07, 2007, 06:29:27 pm
« Reply #11 on: May 07, 2007, 06:29:27 pm »
I have a leak that comes and goes on my IP at the throttle shaft.... when it happens diesel pours out.... rev the throttle a couple of times and it goes away for weeks.
Sadly, problems that fix themselves almost always come back by themselves !!!
Reply #12May 08, 2007, 10:36:40 am
TD_Bunny
« Reply #12 on: May 08, 2007, 10:36:40 am »
How did revving up the engine stop the leaking? Not sure i understand how that stopped the leaking. Either way it does not sound like there is an overflow valve on the IP so i have some sort of problem with it and the pump has not been rebuilt since the change in fuel. Ill be looking at sending my pump over to Giles so i guess i will at least end up with a sweet pump.
On a positive i have had three mechanics say the engine sounds solid and they work on diesel engines.
Reply #13May 08, 2007, 11:19:16 am
tylernt
  • 344
« Reply #13 on: May 08, 2007, 11:19:16 am »
There is a teeny tiny hole in the OUT bolt on top of the pump. This hole helps regulate the internal pump fuel pressure. If a tiny speck of something clogs this hole, the pump will overpressurize and blow a seal. Here's my theory: a chunk of something is floating around in your pump. That one day it happened to cover up that OUT hole, but after you shut the engine off, it floated back down into the pump somewhere. Now it lurks, waiting for the most inopportune moment to clog and make your pump spew fuel everywhere again (and this time, the seals may not reseal themselves!).
I suggest you temporarily replace the OUT bolt with an ordinary fuel banjo bolt and then figure out a way to flush the pump out (don't try to drive the car without the proper OUT bolt installed, though). Maybe put a spare gasser in-tank transfer fuel pump in one bucket of diesel on the supply line, then route the return line into a different bucket. Let her rip and watch for crud in the second bucket.
Reply #14May 08, 2007, 11:55:37 am
« Reply #14 on: May 08, 2007, 11:55:37 am »
Yeah, I have no idea why it it suddenly leaks like Old Faithful and then stops for weeks, but there you have it and I've been able to stop it three times by blipping the throttle... right before my eyes.
I'm with Tylernt that it's likely an internal pressure thing... I have blown out the return line, the OUT banjo, etc... perhaps there is crap floating in there.  It's coming apart to replace the throttle o-ring and throttle bushing anyway, so perhaps the mystery will be solved when I pop the lid.
