Author Topic: 1.6 na injector pump rebuild instructions, advice?  (Read 3738 times)
May 03, 2007, 05:29:46 pm
overdrivegear
  • 120
« on: May 03, 2007, 05:29:46 pm »
Has anyone attempted to reseal a Bosch VE injector pump using the steps here?:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=4353
It looks really straight forward and I don't see any reason that this wouldn't work just fine.  I mean, as long as you reassemble it the same way you tore it down and pay super close attention to details, shouldn't it be fine?
I'm considering resealing mine soon, so if anyone has experience doing it (or by using the link above) let me know.
Thanks!
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
Reply #1May 03, 2007, 10:41:30 pm
  • 3255
    • My collection of HOWTOs
« Reply #1 on: May 03, 2007, 10:41:30 pm »
My only words of caution are:
- keep things clean clean clean
- the thread you point to shows a rebuild... one of these days we should do a thread on the actual teardown.  My biggest oops:  the govener shaft and nut are left-hand threads and it's a really good idea to measure how far the shaft protrudes from the pump body 'cause it's an adjustable setting... the dot of yellow paint should have been my first clue.
Reply #2May 04, 2007, 06:30:15 pm
Op-Ivy
  • 513
« Reply #2 on: May 04, 2007, 06:30:15 pm »
It's not too hard. I'm in the midst of it right now. Just need to reseal and put it back together.
-Take note of how everything goes becuase you will forget things.
-Take pictures if you can of everything and from different angles.
-As Vincent said... Keep things clean!
Reply #3May 05, 2007, 11:14:32 am
AdAm84
« Reply #3 on: May 05, 2007, 11:14:32 am »
I've worked in a fuel shop.......Keep it clean.
Reply #4May 05, 2007, 11:39:33 am
« Reply #4 on: May 05, 2007, 11:39:33 am »
what cleaners can be used on the inside of the pump??? any degreaser / brake cleaner???
