Author Topic: 135bar instead of 155bar injectors in a 1.6TD?  (Read 8578 times)
May 03, 2007, 12:53:23 pm
Black Smokin' Diesel
  • 656
« on: May 03, 2007, 12:53:23 pm »
So I bought a set of mercedes injectors said to be from a turbo engine (so they should be 155bar units). As it turns out, it's stamped 135bar on the injector bodies.
They have about 70k on them and look brand new. I'd like to know if I can use them on my 1.6TD. TD injectors are rated 155bar.
91 Passat syncro 1.8T swapped.
Reply #1May 03, 2007, 01:58:22 pm
« Reply #1 on: May 03, 2007, 01:58:22 pm »
you could.. you might see a bit more smoke though for the extra fuel and less pressure.  if the nozzles have 70k km's you might want to consider fresh nozzles...
Reply #2May 03, 2007, 02:28:27 pm
saurkraut
  • 904
« Reply #2 on: May 03, 2007, 02:28:27 pm »
I've run the VW NA 135 bar injectors in my 1.6TD when my source was temporarly out of new injectors.
The low end was smoother, and the top end was noticeably less.
Being its the same nozzle and pintle, just thicker shims, what I was feeling in performance terms was retarded timing.
With those Mercedes injectors, you'll be getting more fruel, and retarded timing.
Might want to get them reshimmed to 155 bar.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #3May 03, 2007, 02:54:54 pm
  • 656
« Reply #3 on: May 03, 2007, 02:54:54 pm »
How much would a re-shim be?
Reply #4May 03, 2007, 03:40:58 pm
« Reply #4 on: May 03, 2007, 03:40:58 pm »
problem is.. will the springs handle the extra pressure? smog said that n/a springs can bind...
wouldn't decreased break pressure advance the timing? since they open earlier because the pressure is reached sooner?
Reply #5May 03, 2007, 07:11:35 pm
  • 656
« Reply #5 on: May 03, 2007, 07:11:35 pm »
Quote from: "libbybapa"
OR, you can set the injection timing to the n/a spec and end up with better flow and reduced pumping losses.
Andrew
Now that's the kind of option my budget can deal with. I'll get everything back together and have it timed by a shop (unless I can find someone local to me with proper equipement).
Thanks a lot guys!
One last question, how the hell do you make the pre-combustion chambers stick to the head when re-installing it? Two of them just keep sliding out :?
Reply #6May 03, 2007, 07:20:41 pm
  • 5104
« Reply #6 on: May 03, 2007, 07:20:41 pm »
put some grease on them or something?
Reply #7May 03, 2007, 07:57:30 pm
Darkness_is_spreading
  • 288
« Reply #7 on: May 03, 2007, 07:57:30 pm »
I go no meng   maybe some tape
83 Jetta 1.9 T (Project Darkness)
88 Jetta 1.6 NA (Dead/Crushed)
92 Jetta 1.6 T (Sleepin)
96 Golf 1.9 T (Parts Car + Mexican Rust Bucket)
Reply #8May 03, 2007, 10:55:06 pm
« Reply #8 on: May 03, 2007, 10:55:06 pm »
And I bought a new head because the shop told me it was toast since one of mine would fall out?  :evil:  Guess I have a spare head now.
Reply #9May 04, 2007, 07:00:38 am
« Reply #9 on: May 04, 2007, 07:00:38 am »
Quote from: "jimfoo"
maybe time for a new shop?  :lol:
Reply #10May 04, 2007, 07:12:00 am
« Reply #10 on: May 04, 2007, 07:12:00 am »
This is supposed to be THE head shop in Denver. Maybe he doesn't do many VW Diesels. Well, since the IDI wasn't imported here, I can bet on it.
Reply #11May 04, 2007, 12:22:25 pm
  • 656
« Reply #11 on: May 04, 2007, 12:22:25 pm »
Peen the edge in 3 places.
Not sure I understand what you mean.
Reply #12May 04, 2007, 12:57:36 pm
« Reply #12 on: May 04, 2007, 12:57:36 pm »
Remove pre cup, take center punch and make a mark on the inside of the head where the pre cup sits, hit the side of the area where the precup is supose to sit against.  Do this on at least 3 opposing angles and then the precup will need to be taped in place to get it in.
Another term would be swedging. What your doing is deforming the metal in small areas around the precup so the deformed (swedged) metal will cause friction on the sides of the precup. This is inside the head not on the out side/ cumbustion chamber area. Although that may work as well.
Does that make sense at all?
Reply #13May 04, 2007, 02:43:21 pm
  • 656
« Reply #13 on: May 04, 2007, 02:43:21 pm »
Quote from: "zukgod1"
Yes is makes sense :D Thanks a lot!
Reply #14May 05, 2007, 12:23:36 pm
carrizog60
  • 978
« Reply #14 on: May 05, 2007, 12:23:36 pm »
sorry to use your topic but i also have a question related diesel injectors.
i heard about mercedes injectors...what are the beneits of replace by merc ones? wont the car make more smoke at low rpm?
i saw this:
Edited by moderator (reduced URL size):
EBAY LINK
whats is that he his selling?he also have the same kits for vw 1.6 and i am in need of injectors freshen up.
should i go for it?
Portugal
