Author Topic: injector heat shields and injector removal  (Read 11344 times)
Reply #15March 26, 2007, 06:50:37 am
bryankwalton
  • 7
« Reply #15 on: March 26, 2007, 06:50:37 am »
Quote from: subsonic
Who has a socket that will work on the 1.9td injector they want to loan me, or knows where they can get one that works for sure.  I will buy it.
I just recently purchased this socket from Snap-On. http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=68171&group_ID=1326 I can't vouch for it yet (I'm replacing my injectors this coming weekend).  I purchased it for 1.6 N/A injectors and don't know how it would work on 1.9td injectors.  But, it's very long and was designed specifically for VW diesel injectors.  Hope this helps.
Reply #16March 26, 2007, 07:48:51 am
« Reply #16 on: March 26, 2007, 07:48:51 am »
I'll try mine on a 1.9td injector and if it works I'll ship it to you. It'll take 2 weeks to get there though. It's from canadian tire so you can't get it down there
Reply #17March 26, 2007, 06:48:33 pm
subsonic
  • 1836
« Reply #17 on: March 26, 2007, 06:48:33 pm »
Hey Tyler and Bryan,
any luck on the 1.9 injectors?  Some that I checked would have worked for sure on the 1.6, but were just to damn short for the 1.9.  I would like to get these off so I can bring them down and have a set of these suppossed super nozzles put in.  Will have more info on those tomorrow.
Thanks,, Jim
Reply #18March 26, 2007, 06:53:46 pm
subsonic
  • 1836
« Reply #18 on: March 26, 2007, 06:53:46 pm »
Quote from: jimfoo
Can you weld? You could buy 2 sockets, cut one in half and weld it onto the other one.
That would fit for sure!  I dont know how to weld, but I'm not afraid to put the juice and molten metal to it.  I would just need a welder :)
Reply #19March 26, 2007, 06:59:11 pm
insdtanoodles
  • 148
« Reply #19 on: March 26, 2007, 06:59:11 pm »
Quote from: jimfoo
have access to a lathe? I just got the deepest socket I could and bored out the inside of the socket at the back untill it fit over the injector.
1996 vw jetta AAZ
Reply #20March 26, 2007, 10:41:38 pm
« Reply #20 on: March 26, 2007, 10:41:38 pm »
sorry I forgot to check when I was at the garage today, I'll try and remember for tomorrow
Reply #21March 27, 2007, 12:11:22 pm
bryankwalton
  • 7
« Reply #21 on: March 27, 2007, 12:11:22 pm »
Sorry.  I don't have access to any 1.9 injectors to check it out for you.
Reply #22May 25, 2007, 01:06:04 pm
subsonic
  • 1836
« Reply #22 on: May 25, 2007, 01:06:04 pm »
AH HA!  There is more than one way to skin a cat.  After repeated attempts to find a socket deep enough to remove my 1.9td injector bodies I had almost given up.
 :idea:  What if I unsrew the top half first :shock:  :?:
Jezz freakin louise  it came right off.  Look at that little 27mm piece that is left over.  Oh my, my normal socket slips right on!  Yeah baby!!!
Done!!
Reply #23May 25, 2007, 07:48:07 pm
subsonic
  • 1836
« Reply #23 on: May 25, 2007, 07:48:07 pm »
Hey! Don't rain on my parade here!  I am basking in my yankee ingenuity :lol:
Reply #24May 29, 2007, 04:59:30 am
somolovitch3
  • 290
« Reply #24 on: May 29, 2007, 04:59:30 am »
Well now that he's got it apart, he won't have to lug the head around to find a GOOD socket!
Way to go dude! :idea:  :mrgreen:
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #25May 29, 2007, 11:55:08 am
yankeejim
  • 8
« Reply #25 on: May 29, 2007, 11:55:08 am »
www.partsplaceinc.com claims to have the correct socket for $9.95.
'92 Jetta ECOdiesel
Reply #26May 29, 2007, 05:59:37 pm
tylernt
  • 344
« Reply #26 on: May 29, 2007, 05:59:37 pm »
I got my socket from Sears... came in a set of 12pt deep sockets. Only bent one of the return barbs a little.
Reply #27May 29, 2007, 08:12:13 pm
« Reply #27 on: May 29, 2007, 08:12:13 pm »
I checked all the parts stores etc up here except for sears. No one had anything. You could remove the pump and use a wrench if you get desprite. That's how I did it on my 1.6 the first time around.
I was going to offer to buy regular deep sockets and have one of my machinist buddies bore them out for you, but I won't be able to do it for less the $10
